Eliminating brake squeal (repost)
Old 05-17-1999, 09:35 PM
Ray Calvo
Guest
Posts: n/a
Default Eliminating brake squeal (repost)
Sorry for the repost, but thought that possibly this got archived before most had a chance to see it. Due to the wide complaints regarding squeal, wanted to help out as many as I could.<p>Several folks have commented on excessive brake squeal in their A4s. I started geting some in my Avant recently; have advocated doing some hard braking to eliminate it. Well, it does work!<p>With stock pads, my suspicion has been that mild braking causes the brake pads to glaze, and then cause squeal. I had been driving my Avant rather mildly for about 2 months (due to recent run-ins w/ Smokies; nuff on that!). At the end of coming to a dead stop, was getting some brake squeal. Eliminated it in the following fashion.<p>Pick an empty level road with little traffic (esp. behind you). While driving about 40MPH in 4th (Tip owners recommend putting tranny manually in 4th), I applied brake moderately meanwhile applying gas to hold car at steady speed; brake application was heavy enough that needed nearly full throttle to hold speed steady. Hold this for about 8 seconds, release brake, drive steadily for about 30 seconds, then repeat. After this, brakes were totally quiet and have remained that way for past two weeks.<p>Note, this was on 98.5 Avant with totally stock brakes. <p>
Old 05-18-1999, 06:09 AM
G
Guest
Posts: n/a
Default Explanation?
Is there a technical explanation to why doing this would work?
Old 05-18-1999, 07:01 AM
AGaur
Guest
Posts: n/a
It worked for me!
Old 05-18-1999, 08:21 AM
Ray Calvo
Guest
Posts: n/a
Default Re: Explanation?
From what I know, mild braking builds up a "glaze" deposit on the pad surface. Hard braking use heats up pad enough to burn it off. Similar concept to break-in period, whre you have to heat/use pads carefully to burn off resins and compounds created by the manufacturing.
Old 05-18-1999, 01:45 PM
KostaT
Guest
Posts: n/a
I think you're right-on here. I complained about brake squeal at the 10K service and the dealer did what is called a "brake modification". According to my service rep, all they do is grind the pads down a bit.<p>kosta
muscleknight
A4 (B7 Platform) Discussion
04-20-2009 03:41 PM
meq123
02-11-2003 05:32 AM
AZSantorin
03-11-2002 09:23 PM
Dan Lazarine
08-14-1999 05:52 PM
mywheels
11-04-1998 03:51 PM
Quick Reply: Eliminating brake squeal (repost)
