Coil Pack connectors - AudiWorld Forums
Old 06-11-2012, 01:31 PM   #1
hanshy5's Avatar
Default Coil Pack connectors
I've got an 01 1.8t AWM engine. 3 of the four connector tabs that clip into the ignition coil packs are broken. One of them was worse and was giving me a misfire code periodically. My mechanic put some stuff called "dumb dumb" around the plastic connector housing and put a zip tie around it to help. Is there a fix for them without a new harness?
Also, curious about new o-ring my injectors and was looking for some input.
Thanks,
hanshy5 is offline   Reply With Quote
Old 06-11-2012, 06:06 PM   #2
GTA_Driver's Avatar
Why not replace the harness?
GTA_Driver is offline   Reply With Quote
Old 06-12-2012, 06:18 AM   #3
hanshy5's Avatar
I was thinking there may be a kit to do it without going into the big job of replacing the harness.
Old 06-12-2012, 07:19 AM   #4
If the wiring is good, you can probably buy the housings from the audi dealership or even find them online. The wiring harness is just $50 from ECS tuning though - so it's probably cheaper and easier just to do the harness.
jseklund is offline   Reply With Quote
Old 06-12-2012, 05:23 PM   #5
Audiworld Premium Sponsor
Romney-AudiUSAParts's Avatar
You can purchase the plastic electrical connector housings for $12.90 each + shipping from AudiUSAparts.com. Let me know if you need anymore Audi parts.
Romney-AudiUSAParts is online now   Reply With Quote
Old 01-29-2013, 06:43 PM   #6
Quote:
Is it under ignition?
Giga is offline   Reply With Quote
Old 02-06-2013, 12:00 PM   #7
Quote:
The part # is 4B0973724 and you can add the part number to the homepage of AudiUSAParts.com. Please keep in mind that this is just the plastic housing and includes no wires. If you need the wires they are part # 000979237E. That is one piece of wire with a connector on each end. You would need 2 wires per connector. Please let us know if you have any other questions.
Old 02-06-2013, 12:51 PM   #8
ddillenger is offline   Reply With Quote
Old 02-06-2013, 05:23 PM   #9
HJB
Believe that Volvo uses the same connector and it is cheaper from them
http://www.volvopartswebstore.com/sh...roduct=1184517
HJB is offline   Reply With Quote
Old 02-06-2013, 06:01 PM   #10
Those are the ICM connectors. The OP asked about the coil connectors.
Thread Thread Starter Forum Replies Last Post
Popping/ Thumping Noise from Airbox Junius A8 / S8 (D3 Platform) Discussion 7 08-11-2016 07:48 AM
A6 C6 3.2 engine removal for timing chains uble1234 A6 / S6 (C6 Platform) Discussion 3 04-17-2016 04:57 AM
Taz audi allroad 2.5 tdi auto Mumtaz Hussain Audi allroad 0 09-30-2015 07:30 AM
Major Road Trip HZ60 Q5/SQ5 MKI (8R) Discussion 0 09-30-2015 06:48 AM
Audi TT quattro Cylinder 4 misfire HELP!! amdreamer1 TT (Mk1) Discussion 0 09-26-2015 07:56 PM
Tags
30, 32, a4, a6, audi, broken, clip, coil, connector, harness, housing, pack, powered, replacement, vbulletin, wire
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
