Aftermarket turn-off delay...Alpine 7949
Old 04-30-1999, 09:32 AM
Tony O.
Guest
Posts: n/a
Default Aftermarket turn-off delay...Alpine 7949
Attn: Dan Schafer... I've been unable to return reply your Emails. Apparently something wrong with the address...<p>I designed a turn-off delay for the Alpine 7949 using a 555 timer ic. It requires mounting a very small pushbutton in the Scosche bracket bezel. With the ignition off you can press the button to initiate a 1 hour turn-on of the head unit. It works exactly as the Concert Radio but requires the pushbutton to initiate turn-on rather than turning the radio off and back on again. The ignition lead to the radio is matrix'd through diodes so that it can be turned on by the output of the 555 timer IC circuitry or from the ignition source of the A4. You need to connect the output of the 555 IC to an FET transistor in order to get the necessary drive current for the radio. I can scan in a schematic if anyone is interested. All Radio Shack parts..
Old 04-30-1999, 10:34 AM
Koushik
Guest
Posts: n/a
Yes, show us the schematic; PSPICE netlist will do as well . tnx !!
Old 04-30-1999, 05:29 PM
schafari
Guest
Posts: n/a
Default Re: Aftermarket turn-off delay...Alpine 7949
Thank you very much Tony. I kind of get what you are saying. I understand the basics & purpose of the parts. However if you could provide a parts list and schmatic that would be fantastic. We should put it in the FAQ <p>(Sorry about the trouble with my e-mail try which ever one you haven't prior<br>dan.schafer@eds.com<br>schafari@earthlink .net<p>Thank you !!!
riotburn
08-07-2010 10:39 AM
req7audi
Q7 MK 1 Discussion
02-27-2008 01:43 PM
portly
10-03-2005 06:59 AM
S4iowa
05-06-2005 07:41 PM
02tts
11-11-2004 12:00 PM
Quick Reply: Aftermarket turn-off delay...Alpine 7949
