Coin stuck in safety belt receptacle! - AudiWorld Forums
Old 04-30-1999, 06:45 AM   #1
Paul W. Simoni
Guest
Posts: n/a
Default Coin stuck in safety belt receptacle!
Help, I have a unique problem: somehow, a dime fell into the slot in<br>which the seatbelt goes. It is wedged in pretty good. I have tried a retractable<br>claw, the thinnest needle-nose pliers I can find, even double sided tape.<p>The seatbelt slot cannot move enough for me to turn it upside-down, either.<p>Any suggestions before I take it to the dealer?<p>By the way, before anyone suggests it, magnets won;t work because dimes<br>are non-magnetig, as most coins are.
Old 04-30-1999, 06:50 AM   #2
Brian
Guest
Posts: n/a
Default Re: Coin stuck in safety belt receptacle!
How about a pair of tweezers (from mom/girlfriend/wife/drugstore?)
Old 04-30-1999, 07:05 AM   #3
CraigB
Guest
Posts: n/a
Try a wire with a small hook/bend on the end (maybe a coat hanger).
Old 04-30-1999, 07:32 AM   #4
Dave M
Guest
Posts: n/a
Sorry, I don't have a suggestion (the bent wire someone else suggested sounds good, though) but this reminded me of a similar story that happened to me.<p>I was driving one day and while spiritedly going around a corner my cigar cutter flew off the front seat and landed on the floor of the back seat. No problem, I thought, I'll just get it when I arrive at my destination. Well, to make a long story short, in the course of my driving I hit just the right amount of turning and deceleration to make the cigar cutter slide into the rear ventilation tube under the front passenger seat! This amazes me as the tube is slightly wider than the cutter, and the cutter is fairly long (about 1.25" by 3.25"), so there was only one way it could get in there. I did not know this when I stopped, so I basically tore the car apart and could not find my cutter. I looked at the tube under the seat and thought "no way." Well, when I drove off again, I could hear the cutter slide down the tube under heavy acceleration and slide up the tube under hard braking. I could not get it out with my fingers, and eventually got it out by finding a steep hill, driving briskly in reverse down the hill and then slamming on the brakes to get the cutter to slide back out! This will never happen again in a million years.<p>Dave M - '97 1.8tm (occasional cigar smoker - never in my A4!)
Old 04-30-1999, 07:42 AM   #5
DSills
Guest
Posts: n/a
Hmmm....Try that bent silver wire thing that comes in the jack tool compartment. Maybe thats what that thing is for. Or maybe you could try inverting the car and shaking it vigorously until it falls out (similar to Dave M's cigar cutter story)
Old 04-30-1999, 08:23 AM   #6
Drew S.
Guest
Posts: n/a
Default What coins are magnetic? I have one last-ditch solution.
I don't think any (American) coins are magnetic.<p>I thought about your problem and tried to think about it from the perspective of solving the problem with everyday items that anyone might have. I didn't come up with much. However, if you don't have any other tools to use, or nothing is small enough to fit in the seatbelt receptacle slot, then I do have one idea.<p>Take the wiper blade off of one of your wipers. Each rubber wiper blade has two long skinny steel support pieces. These will certainly fit in the belt receptacle. Use these to fish out the coin, but be careful not to bend the wiper supports. When you're done, put the wiper back together and tell people your new nickname is "McGyver".<br>
Old 04-30-1999, 08:51 AM   #7
DavidG
Guest
Posts: n/a
When little, I used to fish coins out of storm drains with gum stuck on the end of a stick. Can you adapt this?
Old 04-30-1999, 08:55 AM   #8
ChrisWB
Guest
Posts: n/a
That wire thing is for removing the caps off the 15&quot; stock wheels.
Old 04-30-1999, 09:08 AM   #9
Philip M
Guest
Posts: n/a
I don't suppose you can disassemble the receptacle can you?
Old 04-30-1999, 10:38 AM   #10
PaulS
Guest
Posts: n/a
Dear Dave,<p>I can relate to your story, especially as a cigar-smoker myself (never in my A4 either).<p>Like you, I was baffled when I tried to buckle my safety belt and found a dime jammed in there. The way I figure it, I could spend the better part of a day trying to intentionally get a dime to go into that slot and not succeed.<p>Well, when I figure it out, I'll let you all know<p>:-( Paul
Thread Thread Starter Forum Replies Last Post
PARTING OUT 2002 A4 B6 1.8T Cmmartin23 Parts For Sale 26 08-23-2016 05:44 PM
What are the odds of a Chinese cam tensioner bad out of the box? Stubborn, but Happy Audi allroad 2 09-12-2015 01:58 PM
Audi A4 B5 2.8 Water Pump and Timing Belt issue xaviertkhh A4 (B5 Platform) Discussion 3 09-12-2015 07:10 AM
2016 Q7 5 Star Safety Rating pcullen Q7 MKII Discussion 0 09-02-2015 01:54 PM
September 20th Mosport GoKarting event 3 - 6pm Sunday! Touge.ca 20+ events 2015!! Touge.ca Canadian Discussion 0 09-02-2015 02:28 AM
Tags
a4, audi, b5, belt, buckle, car, coin, dime, inside, penny, receptacle, remove, safety, seat, seatbelt, stuck
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
