Debadging my A4
Old 04-05-2000, 09:48 AM
New Member
RickCranium's Avatar
Default Debadging my A4
How hard is it to debadge and does it leave holes that would need to be filled.
Old 04-05-2000, 09:59 AM
New Member
Stace C's Avatar
Default Re: Debadging my A4
It's real simple. I used a hairdryer to heat up the glue and some waxed dental floss to "saw" off the badges. There aren't any holes, just a real smooth surface.
Old 04-05-2000, 10:00 AM
New Member
Jorge C's Avatar
Default answers
Not too hard, the badges are glued, not screwed on so there will not be any holes. Just heat up the badges using a hair dryer, then using a fishing line remove the glue and the badge. Clean the residual with water and soap and voila!
Jorge
'99 1.8TQMS
Old 04-05-2000, 10:29 AM
PSS  //  Raj's Avatar
Default you may need to use something like WD-40 or Goof-off to remove the residue afterwards.....
soap and water may not be enough, depending on how much crap is on there.<p>Raj
1.8T Quattro Tip, 17" Avus Wheels, SmartTire, Eurosport Springs
Old 04-05-2000, 10:43 AM
Junior Member
JoeyM's Avatar
Default wd40 doesn't work well, goof off is scary, there are other adhesive removers...but...
with anything that is strong enough to take off the goop, you have to test it somewhere inconspicuous first. if nothing happens then use it.
Old 04-05-2000, 10:52 AM
Audi2Ody's Avatar
Default Goof off is fine, just be sure to wash and wax the area when finished.
<p>Dave Lee
1997 1.8TQMS
Wett 1.0Bar
Borbet Type-T
Old 04-05-2000, 11:15 AM
Member
elton's Avatar
You'll also want to spend a little more time with the hairdryer.. it'll come off easier and the clean up is also easier...
Old 04-05-2000, 11:28 AM
dougie's Avatar
i finished off with a little poishing compound just to make it nice and smoooof.
Old 04-05-2000, 11:56 AM
Junior Member
DougR's Avatar
Default I had good luck with "Goo Gone"...
...as Dave suggests, make sure to wash and wax afterwards!<p>
DougR
'00 1.8TQMS silver/opal
Old 04-05-2000, 12:32 PM
New Member
Thanks for the info guys, i am going to go and try it.
Quick Reply: Debadging my A4
