Fixed: 17964 charge pressure control: negative deviation
Old 08-06-2006, 08:38 AM
Nickle's Avatar
Default Fixed: 17964 charge pressure control: negative deviation
I never posted that I had a problem. I searched the forums and found what I was looking for. I'm posting up the fix to this problem so that others won't have to read through pages of "I have a problem" until they read an "I have a solution" post. Does that make sense? Just trying to help out those who are searching out the same problem. ;-)
I had been feeling the car lose power and not make as much boost. I have an APR 1 bar chip that will hold a solid bar. However, it has been holding around 0.8 bar and hopping of chipped mod under heavy acceleration by the time I am in third. It got so bad that I couldn't even make it to the 1/8 mile mark at the track before it would go into soft limp. No CEL shown. I VAG COMed it and showed only one code: 17964 charge pressure control: negative deviation. I STF's and found a lot of suggestions. Most of which pointed to a boost leak. That was truly the case. I found the following post and accompanying image. That turned out to be my problem. $11.45 later, the car is back to normal. Just thought you all should know. ;-)
<img src="http://pictureposter.audiworld.com/8422/a4leak1.jpg"><ul><li><a href="https://forums.audiworld.com/a4/msgs/2563533.phtml">https://forums.audiworld.com/a4/msgs/2563533.phtml</a</li></ul>
Old 08-06-2006, 08:59 AM
New Member
Fighting-First's Avatar
Default Check the Suction Pump
That hose is connected to the SP and if that hose split, SP is probably next.
Old 08-07-2006, 07:45 AM
Nickle's Avatar
Two questions: What is the purpose of the suction pump and how do I check it?
Old 08-07-2006, 08:09 AM
Nickle's Avatar
Scrath that, STFA. ;-)
Old 08-07-2006, 09:35 AM
New Member
Default The SP is prob OK
mine split in 1/2 where the small end is pressed in and it wasnt noticable.
joeq10
13
01-05-2008 12:11 PM
Aldonis
01-17-2007 02:18 PM
tuneda4
1.8T Discussion
09-18-2006 06:26 AM
SP (oenophile)
13
09-16-2005 11:06 AM
Shoe
08-04-2003 10:53 AM
Quick Reply: Fixed: 17964 charge pressure control: negative deviation
