APR Holiday Sale Update: Carbonio Intakes, Bipipes and Intercoolers 10-15% OFF!
<center><img src="http://www.goapr.com/Audi/products/images/intercooler_fmic.jpg"></center><p>Until December 21, all Carbonio Intakes, APR Bipipe and APR Intercoolers are now on sale!
Carbonio Intakes and the APR Bipipes are 15% off and all APR Intercoolers are 10% off!
Ready for immediate shipment!
Carbonio Carbon Fiber intakes are made of the highest quality materials to provide the best performance gains and enhance the appearance of the engine bay. Thermal insulation and high flow design characteristics are the perfect weapons to deliver the cold air your engine craves as quickly as possible. With gains ranging from 5-20 hp and trq per application, the Carbonio Intake is sure to wake up your power plant with fresh, cool air.
The APR Bipipe is a cast aluminum replacement inlet system for the 2.7T bi turbo engine. Prone to failure, the soft, flexible rubber throttle boot supplied by Audi has always left a strong need for better power capabilities. APR responded by introducing the bipipe over 6 years ago which has quickly become the industry standard for correcting this 2.7T maintenance issue. Allowing for higher flow and less boost flex under pressure through the Bipipe's smoother transitions and cast aluminum design, the APR Bipipe will provide nice gains while outlasting the life of your car!
All APR Intercooler systems benefit from a cast end tank design and the largest cores possible to comfortably fit for your application. With ease of installation in mind, many APR Intercoolers offer the feature of pre mounted intercoolers cores into an APR supplied bumper support. Minimal if any trimming is required.
The APR Intercooler product line ensures superior charge cooling abilities by incorporating a top feed design with angled end tanks to direct the charge flow evenly across the entire core to maximize efficiency with no pressure drop.<ul><li><a href="http://www.goapr.com">GO APR!</a></li></ul>
Keith@APR
22
12-06-2006 07:23 AM
Keith@APR
A4 (B7 Platform) Discussion
12-06-2006 05:33 AM
Keith@APR
12-05-2006 08:22 AM
Keith@APR
12-05-2006 08:14 AM
Keith@APR
Audi A3 / S3 / RS 3
12-05-2006 07:36 AM
