Flywheel bolt torque specs? - AudiWorld Forums
Old 12-04-2006, 05:31 PM   #1
Default Flywheel bolt torque specs?
Well depending on where I look (Bently, Chiltons) I'm finding the torque spec. for the 22.5mm bolts on my '00 ATW 1.8T engine dual mass flywheel to be:
1. 44ft/lbs +90deg or
2. 44ft/lbs +180deg
You wouldn't think the 90 deg difference would be huge, but I've turned them the first 90deg and it is taking some torque!
It would appear that many of the earlier 1.8Ts used the 43mm bolts, and thus would stretch more...
Hopefully someone knows!!!
kgardnez is offline   Reply With Quote
Old 12-04-2006, 06:55 PM   #2
New Member
Default 90 is what I did...
South Bend DXD stage II with the light weight flywheel. I've got about 20,000 on it so far. Just don't reuse the old ones.
constant maintenance is offline   Reply With Quote
Old 12-04-2006, 08:39 PM   #3
Member
Default A comment....
When I replaced the clutch on our 00 30v a few months back, I recall tightening the flywheel bolts with the +180 degree second stage torque spec. I'm not near my Bentley manual but that's my best recollection. It was definitely a bear getting those 180 degrees , lying on the concrete floor in our garage. I used the factory flywheel and crank locks along with new bolts.
My method for remembering(poor memory) was:
-a small mark of red touch-up on the bolt after the initial torque spec.
-then, after the initial steps are all done in a star pattern, I used a white touch up exactly 180 degrees opposite of the previous red paint marks, on the flywheel surface. Then you just line them up. When they are lined up, you know you've finished that bolt. Yes, a bit retentive but the job never gets screwed up.
77'911 is offline   Reply With Quote
Old 12-04-2006, 09:18 PM   #4
New Member
Default I'd imagine the torque settings are a bit different for each kit, right?
Specifically an OEM vs. and aluminum. Never done an OEM so I don't know.
Old 12-04-2006, 09:38 PM   #5
Member
Default a response...
The kit I installed was a Sachs(OEM) clutch kit(reused the old flyhweel over). If your talking about the flywheel, then the spec should be the same as the factory unless specified by the aftermarket distributor(ie alu flywheel or the like). We have an aluminum(fidanza) in one of our other cars and its was torqued to the factory spec with no issues.
Old 12-05-2006, 06:51 AM   #6
Default I don't think marking is retentive at all, I have the initial marks already in place!
Now I just need to know where to end up...
Old 12-05-2006, 09:56 AM   #7
Default Comparison of bolts
I have these bolts (10x1x22.5 for ATW and AWB):
http://www.ecstuning.com/stage/images/product/iadmin/4831_x600.jpg
not these, (10x1x43 for 1.8T through '99 and '00 with AEB engine):
http://www.pelicanparts.com/cgi-bin/smart/imgdsply.cgi?pn=VAG-17346-M211
Thread Thread Starter Forum Replies Last Post
A4 B7 2.0T FSI High Pressure Fuel Pump Valve Removal. Hard Fail! LoPan455 A4 (B7 Platform) Discussion 7 11-09-2016 07:02 AM
:: ECS Tuning :: B8 A4 2.0T ECS Tuning Lightweight Flywheel Kit Collection ECS Tuning-Audi A4 (B8 Platform) Discussion 3 02-08-2016 10:46 AM
:: ECS Tuning :: B8 A5 2.0T ECS Tuning Lightweight Flywheel Kit Collection ECS Tuning-Audi Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-22-2015 01:52 PM
:: ECS Tuning :: B5 A4 1.8T RA4 Conversion Clutch Kits ECS Tuning-Audi A4 (B5 Platform) Discussion 0 09-21-2015 01:41 PM
:: ECS Tuning :: B6 A4 1.8T RA4 Conversion Clutch Kits ECS Tuning-Audi A4 (B6 Platform) Discussion 0 09-21-2015 01:33 PM
Tags
18t, aeb, audi, bolt, bolts, dual, flywheel, mass, s4, spec, specs, torque, touque, tourq, tourque
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
