Help , No Spark
Old 05-24-2008, 01:00 PM
Trixbox's Avatar
Default Help , No Spark
I purchased a 2001 A4 1.8T, Engine Code AWM from a friend who blew the motor. The car was running before he blew the head.
I didn an engine swap and the engine should be fine, but Im getting no spark. The coils are reading almost 4k ohms. The wiring harness is showing 12v on the plugs for the coil packs. I swapped the cam position sensor and the engine speed sensor off the old motor since I wasnt sure if the old ones were working.
I am getting no check engine codes unless I plugged the Engine speed sensor or something else. Everything on the wire harness is plugged in and all the fuses are good.
Do you think the ECU is toasted? Its giving me codes when I try unpluggin a sensor.
Why would I be getting no spark?
Does anyone want to try my ECU in their car, Im willing to drive anywhere in Massachusetts and New Hampshire to try an ECU out.
I opened the ECU case and there was no burnt componets.
Thanks ahead of time.
Old 05-24-2008, 01:35 PM
WJM
WJM's Avatar
Default turn the key to on but do not start... do you see a check engine light?
if not, then your ECU is not working
if you do, then it is something else. Are the coilpack ground wires attached to the engine?
Old 05-24-2008, 01:58 PM
Trixbox's Avatar
Default Re: turn the key to on but do not start... do you see a check engine light?
yes, i see Check Engine and EPC light.
and the coil ground is attached to the valve cover.
Old 05-24-2008, 04:21 PM
DaveInSaltLake's Avatar
check your POS
Old 05-24-2008, 06:41 PM
Trixbox's Avatar
Default Re: check your POS
whats a POS?
power output stage?
its a 2001 , there was never one on the car...
i think they stopped using that in 1998,
right?
whats next?
Old 05-25-2008, 07:54 AM
WJM
WJM's Avatar
you are correct... except they stopped in 99.5...
Old 05-25-2008, 10:17 AM
Trixbox's Avatar
Default So whats next,
VAG-Com I guess
or test the ECU.
Engine speed sensor is testing at 951 ohms which seems good.
I double checked everything twice. I think its time for the good olde carburator and distributor.
bd__14
12v V6 Discussion
09-11-2012 04:24 PM
sirporfi
09-04-2008 05:42 PM
2002blueS4
Performance and Tuning
03-02-2004 06:59 PM
Sheilige
12-24-2003 10:06 AM
bl98263
02-22-2003 01:45 PM
Quick Reply: Help , No Spark
