Headlight puzzler
Headlight puzzler
I spent most of the weekend trying to identify why I have no low or high beams (99 A4, 1.8TQ). I swapped out the headlight switch, which seems to test fine (based on my ohm meter)...still no lights. With the key on, when I separate the 14 pin connector from the switch, I am able to jumper the high beams:female connector X (yellow w/ black stripe wire) to female connector 56 (yellow wire). However, I am unable to jumper the low beams (connector X to connector 56a/white wire). If the X circuit/feed from ignition is hot, which - if I am reading the schematic correctly - powers both the low and high beams, why am I unable to jumper the low beams as well? Is there a relay or fuse that I am missing? I checked all the basic fuses (driver's side fuse box) and they are all fine.
Everything else electric works, including fog lights. Flash-to-pass also works fine. (I'm assuming this feature uses the same ground as the regular headlights so I should not be chasing a loose ground wire...???) When the stalk switch is reassembled, still no headlights.
Thanks in advance for any ideas.
Bump...
Getting desperate..Anybody have the wiring schematic for the 99 model (AEB)? I can't get my Bentley cd to work. Many, many thanks if you can help.
I don't have a wiring diagram, and you probably already checked this, but sometimes we miss obvious answers....did you check the bulbs? I know that isn't the issue with the high beams, but maybe the low beams are causing an issue?
The only relay of sorts that could interfere is the relay in the fuseblock that shuts off the accessories when you are starting the car.
LoPan455
A4 (B7 Platform) Discussion
12
08-21-2019 07:48 AM
Kris Hansen
S4 (B9 Platform) Discussion
40
05-25-2016 07:16 PM
geter
09-29-2015 01:39 AM
Kris Hansen
Audi News Forum
09-15-2015 02:29 AM
