How hard to replace a thermostat to A4? - AudiWorld Forums
Old 07-09-2003, 11:30 AM   #1
New Member
Default How hard to replace a thermostat to A4?
Can someone tell me how hard to replace the
thermostat to A4?
Seems that anything you do to the A4 is always
hard to access.
My car overheated momentarily last night and
I immediately turned it off. After 15 minutes,
I tried it and I get home without overheating.
I suspect the thermostat got stuck....what do you think?
Thanks
lotusflores is offline   Reply With Quote
Old 07-09-2003, 11:43 AM   #2
Default Follow the lower radiator hose from the radiator to the block...
...it's right about there, IIRC. Good luck
Andy
Andy_FL is offline   Reply With Quote
Old 07-09-2003, 11:50 AM   #3
New Member
Default Re: Follow the lower radiator hose from the radiator to the block...
Well, normally most car has the thermostat at the
top hose, tellin me A4 1.8T located on the block
leading from lower hose?
Thanks
Old 07-09-2003, 11:55 AM   #4
Default It's definitely not at the top hose...
...I <b>can</b> tell you that much. I've not replaced one myself, but IIRC from looking at the Bentley once, you remove the bottom hose and there it is. Try a search of the archives, you'll probably turn up something more detailed.
Andy
Old 07-09-2003, 11:56 AM   #5
Elder Member
Default Here's a very exploded view...
It's right under the waterpump in my pics...
You can get to it by removing two 10mm hex screws IIRC.
<img src="http://pictureposter.audiworld.com/1308/tstat1.jpg">
<img src="http://pictureposter.audiworld.com/1308/wpump1.jpg">
Digit@lex is offline   Reply With Quote
Old 07-09-2003, 12:00 PM   #6
Elder Member
Really? Woohoo, I changed something that you haven't touched yet. :-p
Old 07-09-2003, 12:04 PM   #7
Default LOL....was I right though?
Remove the bottom hose, and then those two screws? It's on the list of things to do.....but I've been lazy lately...
Andy
Old 07-09-2003, 12:09 PM   #8
Elder Member
Yup. The lower hose splits, but like you said, follow it to the block and the T-stat is in there.
Old 07-09-2003, 12:25 PM   #9
Member
don't you need to flush the system in order to change the Tstat?
Casablanca Avant is offline   Reply With Quote
Old 07-09-2003, 12:28 PM   #10
Elder Member
Yes. You will need to replace the coolant.
Thread Thread Starter Forum Replies Last Post
Mk1 tt overheating at idle Boosted01tt 1.8T Discussion 5 01-03-2017 05:55 PM
Deciding between a Golf R or an S3- Need some opinions Captain Rossness Audi A3 / S3 /RS 3 MKII 26 09-24-2015 05:34 AM
When to replace shocks and struts - Wobble at 20mph/40mph ZPA117 A4 (B8 Platform) Discussion 4 09-08-2015 11:55 AM
Best way to launch my RS6? LaserSVT RS 6 Discussion 2 09-06-2015 07:54 PM
How do you launch your S6 or 2.7T? LaserSVT A6 / S6 (C5 Platform) Discussion 6 09-05-2015 08:40 PM
Tags
2000, 2001, 2002, 2003, 20055, a4, audi, b5, change, difficult, flush, hard, repair, replace, replacing, thermostat
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
