How To: Replacing the Audi A4 Interior Dust/Pollen Air Filter
Questions about replacing the interior dust/pollen air filter pop up from time to time, so since I recently replaced mine I figured some other folks might like to see some instructions on this simple process.
I purchased a German-made Mann dust/pollen filter from Adirondack Auto Brokers for $19. This filter came with a small set of illustrated instructions, so I decided to scan the images from those instructions and add some descriptive instructions of my own, the result is the PDF file which you can open or save from the link shown below.
The images shown here are based on the early A4's that don't have the extra plastic shroud in between the two firewalls. The filter replacement procedure for the newer A4's is the same as shown here except that you'll need to remove that top shroud also.<ul><li><a href="http://members.aol.com/ajhedin/A4/Pollen_Filter.pdf">How To Replace Audi A4 Interior Dust/Pollen Air Filter (314k PDF file)</a></li></ul>
The replacement interval listed in my 1997 Owner's Manual is.....
....every 30,000 miles. I think that may have changed with the newer A4's....perhaps every 20,000? I'm not quite sure. Check your Owner's Manual for exact interval for your A4.
I should send this to my dealer...
... here in Ottawa, I don't think they changed mine at my last servce (when they should have). I checked it a couple of weeks ago, just after service, and it was very dirty.
Kirk
Kirk
8A0.819.439.A was the item number on my invoice...
....and the number in the Mann filter installation instructions was CU 3955.
rvent
12-04-2002 09:47 AM
