Read coolant temperatures in VCDS Lite
Old 05-20-2015, 12:18 AM
Trianta's Avatar
Default Read coolant temperatures in VCDS Lite
Hi,
8D0 907 558 B, 1.8L R4/5V MOTR HS D02,
From a few weeks ago in the instrument cluster the coolant temperature it only reaches max 75-80 C. (oil temp 90-100 C)
The termostat replaced recently, and the sensor 078919501B (4 pins) replaced 2 yeasr ago.
I need both coolant temperature data at the same time (to ECU and to Instrument cluster).
How to read the coolant temperature in VCDS Lite?
Old 06-01-2015, 12:58 AM
Trianta's Avatar
I replaced the sensor and the gueage indicate 90 degrees. It's ok.
Engine stopped and read temps with VCDS:
The temp in the engine block 99 C and in the istruments block 88 C.
It's so good?
A4 B5 1.8 ADR
Dr.Aronis
RS 6 Discussion (C5)
10
08-09-2009 07:55 AM
Nor
01-30-2006 06:31 PM
gilram01
12-27-2004 08:37 AM
zapco98
05-20-2003 11:45 AM
Quick Reply: Read coolant temperatures in VCDS Lite
