Loose bolt on subframe need solution. - AudiWorld Forums
Old 06-01-2009, 06:17 PM   #1
Default Loose bolt on subframe need solution.
Hello again to all members. When installing the lower, rear (bent) control on the front passenger side of my car I noticed that one of the three bolts on the subframe was loose. The bolt is one of the smaller bolts and is closer to the rear end of the vehicle. When I try to tighten the bolt (or loosen) it just spins around and doesn't go in or out. The other smaller bolt and the larger bolt (closer to the arm itself) is solid and I was able to tighten both of them properly. How much of a risk is it to the car and my safety to just neglect it? What are ways to fix it? Should I pry it out and tap new threads since it seems like the threads are worn out? Thanks for all the help in advance.
moloveshisaudi1254 is offline   Reply With Quote
Old 06-02-2009, 08:59 PM   #2
Default Here is the Bolt in question
The other two are fine and art tightened properly.
Old 06-07-2009, 10:43 AM   #3
A400's Avatar
Mine was also like you described. I think that is where the aftermarket subframe stiffener would hook in. I didnt put an insert in when I installed the bar and havent had a problem. Tim @ NEA said it would be fine as long as grade 8 bolts were properly torqued. Has lack of this bolt caused any problems for anyone?
Rod
A400 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Popping/ Thumping Noise from Airbox Junius A8 / S8 (D3 Platform) Discussion 7 08-11-2016 07:48 AM
A6 C6 3.2 engine removal for timing chains uble1234 A6 / S6 (C6 Platform) Discussion 3 04-17-2016 04:57 AM
Sluggish Performance Solved - Replaced Intake Manifold Links Galco A8 / S8 (D3 Platform) Discussion 15 10-19-2015 04:56 AM
License Plate Bolt Length? schalliol A6 (C7 Platform) Discussion 13 10-03-2015 07:56 AM
Tags
100, a3, a4, audi, bolt, bolts, car, fix, frame, insert, loose, mount, subframe, threads, vr6
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
