Need Help ASAP Please - (Power Steering Question)
Old 09-01-2007, 08:26 AM
New Member
MikeUC45's Avatar
Default Need Help ASAP Please - (Power Steering Question)
First of all, I have a 1997 A4 2.8 FWD with 107,000 miles on it. I have known for quite some time that I have a small power steering leak. For the past two days, whenever I start my car in the morning, there is a strange moaning noise coming from the engine bay. it eventually goes away after a little while. I am assuming my fluid level is getting too low. The shop I go to is closed until Tuesday. Am I OK to wait until then to have them top off my fluid? Any help is greatly appreciated.
Old 09-01-2007, 08:44 AM
Tech Guru
4Driver4's Avatar
Default Why can't you just top it up yourself?
This might be a good time to address the leak.
Old 09-01-2007, 08:49 AM
Senior Member
Gldnrkt(GT3076R)'s Avatar
Go to the stealership and buy a bottle, top it off your self....it's easy.
Old 09-01-2007, 08:56 AM
Member
freakness's Avatar
Default Just get some of the power steering fluid "with conditioners" that is compatible with your car...
At your local unfriendly and ignorant auto parts store.
Old 09-01-2007, 08:59 AM
Audi4780's Avatar
Default I had a small leak as well, turned out one of the hose clamps on the reservoir was bad...
If you hear groaning then you definitely have a low power steering fluid level. Not good for the pump if the fluid is low. I would only drive it to the dealership to get some fluid.
Check out the hoses going to the reservoir, could be one of the clamps is no longer holding tight enough. Easy fix to do.
Old 09-11-2007, 05:50 PM
Junior Member
nogarobluedemon's Avatar
Did the fluid end up being the problem?
ddunham
05-13-2009 06:54 PM
MikeUC45
12v V6 Discussion
09-01-2007 10:53 AM
PLethal
07-10-2007 11:58 AM
Recaroblue
9
11-23-2004 06:55 PM
octane 93
07-16-2001 01:06 PM
Quick Reply: Need Help ASAP Please - (Power Steering Question)
