No flow to heater core - AudiWorld Forums
Old 11-04-2009, 02:07 PM   #1
Default No flow to heater core
Hello! I ahve searched this forum for a solution, and the eBahn manual.....so, here goes. We have poor heat. We have heat, but low. I have flushed, etc etc. The radiator and the coolant are now new (radiator was leaking), and a couple years ago I replaced all the front motor seals water pump thermostat etc. The problem started before this. The vehicle stays at the same temperature, not matter what I do (the thermostat and water pump are fine). The oil temp stays the same too. So here is the problem. I went out to backflush the core, and did get some flaky stuff out, but not so much that I was really concerned. The flow was fast, in both directions. So, great. I hook the hoses back up, leaving the outflow open a bit to bleed. Nothing much comes out.
So, I pull the supply tube. The problem is that there is little supply to the heater core. Has this problem been discussed previously? And if so, what should I do?
I plan on draining the system, and then hooking up the garden hose to the supply hose, and backflush that. But I do not know the circuitry. Any ideas will be helpful.
Thanks,
Geoff
gbove is offline   Reply With Quote
Old 11-06-2009, 06:10 AM   #2
No replies? Oh well. If I find the solution, which may be the root of many of the issues I haveread here, I'll share.
Geoff
Geoffrey Bove is offline   Reply With Quote
Old 11-06-2009, 02:09 PM   #3
Try removing the three screws holding the plastic coolant tank, then lift it as high as the hoses allow, with the filler cap off, and see if you begin to get coolant flowing out of the heater supply hose.
turbo510 is offline   Reply With Quote
Old 11-20-2009, 07:21 AM   #4
I had the same problem. Ended up using a pump to recirculate SuperFlush through heater core for about an hour. Suposedly there is a special tool to bleed the heater core, I used a plastic bottle as a funnel on the coolant tank - the trick is to get the coolant level at the tank higher than the heater core while using the bleed hole on the out line at the core. Hope this helps, its nice to have heat again.
jaswes01 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Fault Codes Kerry G Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 3 06-07-2016 03:55 AM
:: ECS Tuning :: B6 A4 WeatherTech Floor Mat Collection ECS Tuning-Audi A4 (B6 Platform) Discussion 0 09-30-2015 07:08 AM
:: ECS Tuning :: B7 A4 WeatherTech Floor Mat Collection ECS Tuning-Audi A4 (B7 Platform) Discussion 0 09-29-2015 12:59 PM
:: ECS Tuning :: B6/B7 S4 WeatherTech Floor Mat Collection ECS Tuning-Audi S4 (B6 & B7 Platforms) Discussion 0 09-29-2015 12:54 PM
Car Completely Dead: No Power gakor A4 (B6 Platform) Discussion 1 09-27-2015 03:10 PM
Tags
1998, 2002, a4, audi, bleed, coil, core, f150, flow, heater, heating, hoses, intitleforums, problems, tubes
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
