No Heat
No Heat
I have 2001 A4 2.8 Quattro.
I have had my timing belt and thermostat and water pump change 4 months ago. I have no heat, when I first turn the heat on you can feel the heat then it start blowing out cold air.
I have read many DIY on Heater Core. One is particular I want to follow:
Heater Core Flush | AudiWorld
I am a lose on how you suppose to get flush the system. I understand about hooking up the tubing. How am I suppose to flush the system? This article mention turn on the water flow not sure I understand that correctly. Do they mean hook up a water holes to it.
If someone can share some light on this process to help me understand clearly I will appreciate it.
Thank you,
Thank you,
Yeah they basically mean put a hose in the left side and use gentle water pressure to just flush it for a couple minutes. The heater core is pretty tiny.
This is literally what you are flushing out:
New on the left, old on the right. Note the two nozzles are the things sticking out of your firewall
If you search this forum for heater core problems you will find quite a history. This particular link is the best.
https://www.audiworld.com/forums/a4-...2860332/page2/
Old School Audi tore apart the heater core and showed why this vintage A4 has issues. I think this particular thread should be a Sticky.
Articus I have a few questions. When I flush the system will I need to put G12 back into the car? What is CLR and where can I get that from? Will I need to flush the right side or only the left side. Sorry for all the questions.
Thanks
Thanks
Whatever goes inside the left nozzle will come out of the right side nozzle and vice versa. The logic is that coolant pumps into the right nozzle when the heat is on and comes out the left nozzle therefore any sediment in the coolant will get trapped in the fins on that side. Pumping in the reverse direction (into the left and out the right) is the best way to remove any sediment. Then just do it in the right direction like that link said to double check cleanliness.
Don't use prestone ****t. I promise you'll f up your car. Stay within audi spec, the coolant is for your aluminum engine components. No tap water! If you heater core is clogged up, most likely the prev. owner(s) used tap water and/or it's never been flushed(Audi says it's lifetime...BS).
CLR is the same as lime away. Technically it's a solvent used for oxidized metal and finishes.
Picture eggshell growing in the surfaces of your heater core and that's what you have. Sometimes it's better to change it outright. Good luck man
I completed the flush of the system today. There was a lot of whatever that came out that did not look good. The fluid was dark orange.
After I completed the flush I put some G12 back into the system.
I waited about 3hrs before I drove the car. To my surprise there is still not heat. What else could be the problem?
Disappointed....
Thanks
Disappointed....
Thanks
