Noise when turning Steering wheel - getting louder - AudiWorld Forums
Old 04-07-2009, 04:34 PM   #1
Member
Default Noise when turning Steering wheel - getting louder
What could it be? I'm certain it's not the ball joints, but could a tie rod make that type of sound? A rubbing/creeking sound.
Help!
yiannaaudia4 is offline   Reply With Quote
Old 04-07-2009, 07:30 PM   #2
Quote:
Help!
If you hear a grinding noise while the steering wheel is turned and held at an angle and the car is moving in a curve the noise may be from the front wheel bearings lift the car up and test each side by rotating the wheel and feeling for vibration and resistance in movement. If the noise only comes while turning the steering wheel and regardless of weather the car is in motion or not then check you power steering pump tie rod ends. Also make sure to check your serpentine belt to make sure its aligned properly and the right tension because it runs the PS pump.
moloveshisaudi1254 is offline   Reply With Quote
Old 04-07-2009, 07:34 PM   #3
Member
I guess the sound is more like a whining...I'm pretty sure it's not the bearing.
Old 04-07-2009, 08:00 PM   #4
Check your Power Steering pump and PS fluid level.
Old 04-08-2009, 02:08 PM   #5
Former Vendor
Did you put the right PS fluid in? It is most likely a bad PS pump.
AP-Specialties is offline   Reply With Quote
Old 04-08-2009, 09:05 PM   #6
New Member
Just get your car checked as soon as possible. There are chances of any obstacle in your smooth power drive.
vandy07 is offline   Reply With Quote
Old 04-13-2009, 10:25 PM   #7
Help!
get the power steering checked. mine started making a whiney noise a while ago and it turned out i had a slow PS leak.
laurenB5 is offline   Reply With Quote
Old 08-05-2009, 04:22 PM   #8
Default power steering grinding and noise
Quote:
i have same problem, it was running fine and started making all these loud grinding noises when turning wheel but if its standing still the pump makes this loud type of clicking noise. and i drove it a lil and it turns on and off like on a turn it help me steer then stop and id have to put lot of effort to turn and if i turn wheel really slowly the power steering is there when faster no PS i thot was the pump and got a used one changed it and no noise but no power steering put in fliuds, now it was running fine with stock ps pulley since i changed it thats when started making noise, but i highly doubt its the pulley,,
peshkis06 is offline   Reply With Quote
Old 08-05-2009, 04:25 PM   #9
and like i said when changed the pump no noise when turning or standing still, so its prob not my front wheel bearings.
Old 08-05-2009, 07:40 PM   #10
Does it make the noise if the steering wheel is turned while the car is stationary? or only while moving? If it is only while moving it could be the beginning of a bad CV axle. Check to see if your boots are torn.
branshew is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Audi A6 FS: 370mm Alcon / Stasis Front Big Brake Kit! Allroad BBK N'Syncro Parts For Sale 12 01-24-2017 04:46 PM
DIY Remote start Q5 IntheQ5 Q5/SQ5 MKI (8R) Discussion 27 06-09-2016 01:37 PM
Cabriolet steering wheel question mrprism133 Audi 90 / 80 / Coupe quattro / Cabriolet 7 09-07-2015 08:22 PM
S-Line - What years have the 3-spoke, etc.. Curtisjh A6 / S6 (C6 Platform) Discussion 7 09-04-2015 05:06 AM
95 Cabriolet Wheel Alignment Issues. stormchaser1967 Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-02-2015 09:48 AM
Tags
2001, a6, audi, engine, grinding, grinds, gti, make, noise, rod, s4, steering, tie, turning, wheel, whining
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
