Ok I need some pointers for Turbo Timer install.....please
Old 06-08-2003, 06:45 AM
Member
A4_THOR's Avatar
Default Ok I need some pointers for Turbo Timer install.....please
I want to make sure I understand correctly in reagrds to the E-Brake.
When the E-Brake is up/engaged there is a 12v constant running so the car will continue to run until the timer counts down to zero? When the e-brake is down/disengaged there is 0v and this would cause the car to shut down?
Being that my car is a manual and I would lift up the e-brake before shutting of the ignition , I have no need to mod the e-brake brown wire for the TT , is that correct?
Also if I chose not to solder but instead use T- Tap connectors can someone tell me the write kind/size and anything else I might need if I chose the solderless route?
Tia
Old 06-08-2003, 12:02 PM
audimods's Avatar
all you need is the brown/white wire from the ebrake. i'm in socal if you need help.
Old 06-08-2003, 04:36 PM
Member
A4_THOR's Avatar
Default confused now
what do i need to do with the brwon/white wire from e-brake?
i thought the part with the brown/white wire is only necessary if you do not lift/engage the e-brake when parking?
Old 06-08-2003, 04:50 PM
audimods's Avatar
Default its for when you drop the ebrake after pulling the key out
most people don't need it. esp if you have a auto.
Old 06-08-2003, 04:56 PM
Member
A4_THOR's Avatar
Default but thats what i was saying in my original thread
i wont be dropping the e-brake after pulling the key out. Im a manual and will have the e-brake up.
So im pretty sure now I have no need to do anything to the brown wire since i'll have the 12v constant running through it.
The only thing left before I tackle this is to decide if i will solder or not....any thoughts?
415Euro
03-29-2012 02:34 PM
bjaro5187
06-16-2005 04:10 PM
ndnbrav
05-12-2005 08:37 PM
Dr.S4
09-23-2001 05:57 PM
hurricanesteve
08-29-2000 11:45 AM
Quick Reply: Ok I need some pointers for Turbo Timer install.....please
