Power door locks don't work - AudiWorld Forums
Old 06-11-2011, 10:11 AM   #1
Default Power door locks don't work
Hi everybody,
I just bought a '99 A4 2.8 Quattro. I'm new to Audi so I've got a lot of questions. I've only got one key, no remotes and the power door locks don't work. I can manually lock the passenger doors from the inside and lock the driver door with the key from the outside. I've scoured the forums and gotten all kinds of good information, but I guess I lack info like is this car equipped with a stock alarm and am I supposed to have a remote? I've read a great deal about the central locking pump but before I go for that could it just be a fuse or electrical issue in the door? The gas door remains unlocked as well.
Another stupid question: I've read in the manual about neat tricks you can do with the key like convenient roll down/up of the windows but this stuff is confusing when it doesn't work.
Any help is appreciated and thanks for taking the time to respond to something you've probably heard ten thousand times before.
Thank you!
Delvekio is offline   Reply With Quote
Old 06-11-2011, 10:33 AM   #2
Tech Guru
4Driver4's Avatar
If you are in the US, the car has a factory alarm and you should have a remote that is part of a switchblade key.
4Driver4 is offline   Reply With Quote
Old 06-11-2011, 11:01 AM   #3
I am in the U.S. but no remote or switchblade key. Do I have to go the dealer or is there a cheaper solution?
Old 06-12-2011, 09:34 AM   #4
mtroxel's Avatar
Don't spend $$ on a remote till you get the power locks working. If you lock the driver's side door, everything else (including the gas door) should lock. In normal operation, you can hear the pump in the trunk behind the RR wheel. If you lock the driver's door and don't hear the pump, there's no point in buying a remote. You need to sort through that problem first.
mtroxel is offline   Reply With Quote
Old 06-12-2011, 10:43 AM   #5
I have a 2000 A4 2.8 with a the same problem. The graphite disks in my locking pump are shattered.
CaptinGonads is offline   Reply With Quote
Old 06-12-2011, 01:15 PM   #6
Okay I'll go check the pump first then. Thanks for the advice.
Old 06-12-2011, 02:02 PM   #7
Heres my pump. The graphite disk looks intact but the electronics are a little worrisome.
Old 06-12-2011, 09:37 PM   #8
There are three disks. The outer ones are not likely to shatter but the center one that actually handles the pumping is divided into four quadrants held at a weak center point. If the pump stil hums when you lock the driver door with the key and the alarm is activated then that center one is probably done for.
Old 06-13-2011, 12:36 AM   #9
MTykhnenko's Avatar
Quote:
There is too much corrosion. Easily fixable if you have a soldering iron and some isopropanal along with a old toothbrush. Clean off all the corrosion with the alcohol and tooth brush, then restore all damaged conduits by scratching their surface off and putting solder in between.
MTykhnenko is offline   Reply With Quote
Old 06-14-2011, 05:53 PM   #10
The disks are definitely shattered. But I still don't have power to the pump. Time to check some fuses.
Thread Thread Starter Forum Replies Last Post
Audi A6 FS: 370mm Alcon / Stasis Front Big Brake Kit! Allroad BBK N'Syncro Parts For Sale 12 01-24-2017 04:46 PM
MMI Car button Doesn't work 2004 audi a8l hellonwheels33 A8 / S8 (D3 Platform) Discussion 27 09-02-2016 01:29 AM
DIY Remote start Q5 IntheQ5 Q5/SQ5 MKI (8R) Discussion 27 06-09-2016 01:37 PM
95 Cabriolet Power Roof Fix. stormchaser1967 Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-02-2015 10:26 AM
95 Cabriolet Power Window Issues. stormchaser1967 Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-02-2015 10:02 AM
Tags
1996, 1999, 97, a4, a8, audi, automatic, dont, door, locks, mazada, miata, power, tt, work
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
