HELP!!! Front windows will not roll down...
Old 06-10-2009, 03:14 PM
ProSkierNJ's Avatar
Default HELP!!! Front windows will not roll down...
front windows will not roll down. I tried a switch that i know works and i tried a motor from another car's door that i know works. All that happens is i hear the motor clicking when i hit the button. where do i go from here?
Old 06-10-2009, 03:23 PM
Allroady DungBeetle's Avatar
Bad ground and/or poor connection? Test power to it?
Old 06-10-2009, 06:21 PM
bmann's Avatar
Try a different harness?
Old 06-10-2009, 06:27 PM
bmann's Avatar
Nevermind, I guess that's essentially the same as trying a different switch. If it's not one, it's the other. If the motor works correctly for the other windows then it's not the motor. It has to be the wiring or the window regulator. Good luck!
Old 06-10-2009, 06:28 PM
bmann's Avatar
my bad, each window has it's own motor. Boy I sure wish you could edit posts. :P
Old 06-11-2009, 06:41 AM
Omega Supreme's Avatar
Something has told the motor that the window is jammed.... make sure the track is clear of debris. The motor has sensors in it that are delicate. When you push on the window switch does the light go out??? if so something is telling the motor that the window is jammed. disconnect the motor and re attach.
Old 06-11-2009, 08:22 AM
ProSkierNJ's Avatar
It's not the switch or the window motor. Neither one of the front windows will roll down. I tested the pins on the harness going to the motor and pin #7(the one with the big red wire with a yellow stripe) which i suspect should get a constant 12v because the similar wire (red with a black stripe) that goes to the #7 pin on the rear window wiring harness gets a constant 12v and that one does roll down. anyone know how to fix this?
Old 06-11-2009, 11:04 AM
dorsal900's Avatar
Blown fuse? If there is supposed to be constant +12V on the red wire and there isn't, ... I don't have a diagram here so I'm just guessing.
Old 06-11-2009, 02:01 PM
ProSkierNJ's Avatar
found the problem. it was some weird little fuse buried under the dash.
Old 06-11-2009, 02:15 PM
dorsal900's Avatar
Thanks for the confirmation!
Quick Reply: HELP!!! Front windows will not roll down...
