removing an ignition cylinder on a 1997 a4 quattro - AudiWorld Forums
Old 03-10-2011, 04:24 PM   #1
Default removing an ignition cylinder on a 1997 a4 quattro
can anyone point me in the direction of replacing an ignition cylinder.. i am pretty good with cars and was hoping to find a cheaper way to do this.. i bought a new cylinder and key for a 1997 audi a-4 2.8 quattro.-- a local locksmith wants 250$ to swap it out.... please help
moeron2 is offline   Reply With Quote
Old 03-10-2011, 05:12 PM   #2
Tech Guru
4Driver4's Avatar
Did you check the Tech Section? Pretty sure there is a write-up there.
4Driver4 is offline   Reply With Quote
Old 03-11-2011, 06:54 AM   #3
mtroxel's Avatar
I did the same on my 96 A4. Bought a new cylinder and just carried the new key and the key fob. Here's what Bentley told me to do. It never worked, so I finally drilled a small hole through the cylinder where the latch is that's supposed to release. Worked great. If you mangle the lock, who cares?
mtroxel is offline   Reply With Quote
Old 03-11-2011, 07:15 AM   #4
mtroxel's Avatar
I should add, if you have to do my drill hole technique, all you need is a small hole to push on the little lever that's locking the cylinder in place. If you do it right (and it's not too hard) you'll leave that housing in place so that the new cylinder will catch the same part of that casting.
Old 03-11-2011, 07:19 AM   #5
Tech Guru
4Driver4's Avatar
That's the way I do it. Drill, baby, drill.
mtrox, I see you tried to PM me. My mailbox is full. I hate the AW PM system and miss the KAWF system where everyone had visible email addresses. If you (or anyone else) wants to contact me, tmullaneATgmail gets it done. Thnx.
Old 03-11-2011, 07:35 AM   #6
mtroxel's Avatar
Quote:
Yea I did. Take a look at my post here please. Wondering if my incorrect knock sensors are causing my problem.
http://forums.audiworld.com/showthre...2801084&page=2
Old 03-11-2011, 11:02 AM   #7
There was a recall on Ignition Switch. Had mine replaced 3 years ago for free. I live in Canada but, should also apply to states.
http://www.arfc.org/autos/audi/a4/re...13/recall.aspx
joloya is offline   Reply With Quote
Old 03-11-2011, 11:16 AM   #8
Tech Guru
4Driver4's Avatar
Responded. You need a TBA. :-)
Old 03-14-2011, 05:31 PM   #9
i didnt see anything specific but thanks anyway
Old 03-15-2011, 03:48 PM   #10
u around?
Thread Thread Starter Forum Replies Last Post
2002 A4 3.0 quattro variable length intake manifold broken levansula A4 (B6 Platform) Discussion 20 08-02-2016 07:11 AM
Fault Codes Kerry G Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 3 06-07-2016 03:55 AM
Audi TT quattro Cylinder 4 misfire HELP!! amdreamer1 TT (Mk1) Discussion 0 09-26-2015 07:56 PM
'94 CS100 Quattro Transmission questions Tristan Anton Snyder Audi Original "S" Cars 0 09-23-2015 10:57 PM
1991 200 avant quattro brake master cylinder bazookatooth Audi 5000 / 200 / V8 Discussion 4 09-12-2015 08:18 AM
Tags
1995, 1999, 2000, a4, audi, b5, chevy, cyl, cylinder, ignition, keys, removal, remove, removing, suburban, tumbler
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
