reset check engine light?
Old 01-05-2011, 06:20 PM
  #11
xsrfsno225x's Avatar
Originally Posted by AudiMick
Second that, spectacularly bad idea. Resetting the computer is also counter productive as the readiness codes are also not set.
It is not a bad idea. All you're doing is uncharging a circuit board. And after about 35 miles, the readiness codes will be fine for any OBDII or vagcom diagnostic.
Old 01-06-2011, 02:58 AM
  #12
Tech Guru
4Driver4's Avatar
Not true. You a de-powering *all* the control units in the car. Not just one. Setting may be lost, and better have the radio code handy.
Do it right. Use the tool.
Old 01-06-2011, 06:29 AM
  #13
AudiMick's Avatar
What you are doing is resetting all setup parameters for the car to default. All the learned info is discarded, and if the initial fault was not corrected (oxygen sensor for example) this could cause the car to run even worse than before.
When they spec'd OBDII they considered that sellers or owners would try to use the battery disconnect trick or remove the CEL bulb to clear a CEL, or to pass emissions.
It doesn't work. And if your car won't even move it's a real problem.
Old 01-11-2011, 08:31 PM
  #14
not true. i did this. and passed very strict CA emissions aka "smog" test.
whatever this is a dead thread.
Old 07-19-2012, 03:55 PM
  #15
Iguana6699's Avatar
Default '98 A4 and OBD II
I tried to reset my check engine light with my OBDII today and it didn't clear anything (with ig on and engine off). Manufacture date is 06/98. Using MaxiScabn tool, check engine light did not reset. Guess I need a VW/Audi one. (The light came on due to low coolant level after alternator/battery replacement - I think). The OBD worked on every other car I have had except this one. Also threw 4 codes - 0160, 0501, 1545 and 1600.
Old 08-09-2016, 10:10 PM
  #16
Ptreaster's Avatar
Originally Posted by 4Driver4
This is a bad idea. It reset a lot more than just the CEL. Do it right. Use a tool.
so what you are saying is that you can never change the battery because it will screw up the computer??
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
carl viking
36
04-27-2020 01:17 PM
zhaoweitian
A7
09-01-2015 03:15 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
Quick Reply: reset check engine light?
