searched and couldn't find a definite answer..do i need an alignment after changing tie-rods?
Old 12-02-2004, 11:11 AM
Member
rfan-r32's Avatar
Default searched and couldn't find a definite answer..do i need an alignment after changing tie-rods?
i'm getting an alignment right and they said that i need new tie-rods. they said they could do the tie-rods for me for $250..but i'd rather just do it myself. but would i need to get another alignment after that?
Old 12-02-2004, 11:12 AM
Andy_FL's Avatar
Yes.
Old 12-02-2004, 11:17 AM
EDness's Avatar
Default yes.
i did mine and now it's way off.
Old 12-02-2004, 11:24 AM
kenny (dremel)'s Avatar
"What the... I can't steer!"
Old 12-02-2004, 11:40 AM
azndrunk74's Avatar
Default When I installed new tie rods I counted the exact same number of threads but alignment was still off
so yes you need an alignment.
Old 12-02-2004, 11:49 AM
Junior Member
Vic995's Avatar
Default If you do them yourself...
you might find that the factory put the thread locker stuff on the tie rod threads and not the jam nut. On my 1999.5, it was a PITA to break the tie rod loose, because of that.
As for alignment, I used a $12 tool from Harbor Freight, to verify that "just a little" toe-in was set in (of course this is after setting the tie rod ends so that the steering wheel was centered perfectly).<ul><li><a href="http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=30167">Tool link</a></li></ul>
Old 12-02-2004, 12:05 PM
SilverA4Fun's Avatar
rob..unfortunately..yes you'll need another alignment afterwards
Old 12-02-2004, 12:16 PM
Junior Member
Vic995's Avatar
Another thing, replacing the Tie Rods ends ONLY effects the Toe (as in toe-in or toe-out)
Old 12-02-2004, 12:35 PM
AaronBryan's Avatar
Default at NTB or Tire Kingdom I paid 180 buck and I get aligned any time I want for free, not a bad deal..
for life too, even if I get a new car
Old 12-02-2004, 12:54 PM
Junior Member
ACCDA4's Avatar
I used digital calipers when installing mine. No alignment needed.
Quick Reply: searched and couldn't find a definite answer..do i need an alignment after changing tie-rods?
