Very little to no heat after waterpump/tb job.
Old 01-11-2010, 08:11 AM
cfurlan's Avatar
Default Very little to no heat after waterpump/tb job.
I replaced my timing belt, tstat, and waterpump on my 1997 2.8recently, and now I have no heat at idle but when I run it at 4000 rpm it warms up. My running temperature is around 200F and the coolant gauge is straight up. I know that the thermostat is opening. I also had a coolant flush, and flushed the heater core 3 times with good flow. I bled the system after the core flush. Both hoses on the heater core get hot. Thanks for any help
Old 01-11-2010, 03:00 PM
anarchyjet's Avatar
Air in the cooling system. Search for bleeding the cooling system. It is a very easy fix.
Old 01-11-2010, 04:12 PM
Tech Guru
4Driver4's Avatar
Agree. Cooling system not completely bled.
Old 01-12-2010, 04:11 AM
cfurlan's Avatar
Ok then I will try it again. Thanks
redrubberband88
01-19-2018 01:32 AM
tarpeyphoto
02-21-2014 05:31 AM
justininaz
08-25-2011 02:12 AM
bdawg4snow
01-14-2011 09:37 AM
eisman.s4
11-26-2005 06:15 AM
Quick Reply: Very little to no heat after waterpump/tb job.
