Since I've spent some time away from AW, I figured I'd show you what I was doing :)
<center><img src="http://pictureposter.audiworld.com/16909/vr4leftrear.jpg"></center><p>This is what I've built in the offseason, but don't worry the Audi will be ready this spring as well
1992 Mitsubishi Gallant VR-4 #256
TRE ported 16G turbo, with 34mm wastegate
Turbotrix stainless braided turbo oil supply line
Mofugas 2.5" turbo-back exhaust, mandrel bent, aluminized
Mofugas Hi-flow CAT or test pipe
Ported 2G exhaust manifold
Ported O2 Sensor housing
ACT 2600 Clutch w/ stainless braided line (Motul 600 Fluid)
2G K&N FIPK
2G MAS w/ 2.5" Dejon Pipe
K&N Crank Case Breather Filter (soon to be replaced by a RRE Catchcan Breather)
Larson Red Silicone Hose kit
Denso 660cc Injectors
Rewired fuel pump
Walbro 255lph (stock pressure) Fuel Pump (To be installed)
Apexi S-AFC
Turbo XS Dual Mechanical Boost Controller
A-pillar Dual Gauge pod w/
Greddy 60mm Peak & Hold EGT Gauge
Greddy 52mm Boost Gauge
Dawes Multi-colored LED A/F Meter
DSM Pocketlogger Palm III on Dash Mount
Greddy Turbo Timer III
Battery relocated to trunk
Maganacore 8.5mm Spark Plug Wires
NGK BPR7ES Spark Plugs
Metalmaster brake pads
Mofugas Short shifter
Symborski shifter bushings
17" Moda R2 Wheels w/ 235/40/17 Kumho ECSTA Supra 712 tires
15" BSA Racing Wheels w/ Nitto NT-460 tires
15" Stock Wheels w/ no tires
Eclipse Steering wheel
KYB/AGX Adjustable Shocks/Struts
Ground Control (Eibach) Coilover Springs
Whiteline Front and Rear Adjustable Strut Tower bars (Ordered)
K & N Performance Gold oil filter w/ 15w50 Mobil 1
BG Synchroshift II Gear Oil (Gearbox)
Redline Shockproof Gear Oil (X-fer and rear Diff)
Tinted Windows
Hiper Super Plasma Headlight & Fog bulbs
Sony Xplod ES I.C.E System
2G K&N FIPK
Rewired fuel pump
Apexi S-AFC
Tinted Windows
holy sheet.. didn't know you can still get that...
4ws/4wd.. used to rule the rally stages for .. a year or two? but none the less.. great car..
does yours have a little plate saying it's Limited edition?
