Springs ONLY question
Guest
Posts: n/a
Question for all people who have upgraded their suspension components: I want to lower my A4 a tad (1 inch+ or so F&B) and would like to get springs only, no shocks. I have a 98.5 1.8T, NON SPORT, and use 205/55/16 SP8000 tires for summer, 195/65/15 Gislaved Nordfrost tires for winter. Will this spring replacement cause any problems w/ my wheel setup? Or should I just get the shocks as well? Pricing- reasonable estimates would be appreciated. TIA
Guest
Posts: n/a
Re: Do it the right way and go for both, because you will still have to pay for it in the future.
I second that, since spring/shock combination is designed and tuned as a unit by manufacturer. When changing just the spring ( effectively changing the spring rate) you are bound to have an out of tune suspension.
Guest
Posts: n/a
No way.
Sure you can do it. Then you will have to take it all apart again in 3 months when the shocks go; let alone enjoying the pogo ride before they blow.<p>If you don't have enough much money for a coilover, buy a factory sport setup in the classifieds.
Guest
Posts: n/a
Thanks for all the replies
Well I guess I won't be going the route I planned. I apprciate all your advice, makes sense now that I've had a few hours to think about it. I'll keep you all informed as to what actually happens.<p>As an aside, anybody know a good shop in the Metro NYC area that could put the spring/shock combo on for me and won't charge an arm and a leg? TIA. Rob
loTTusmark2000
Chicago Discussion
06-05-2008 10:25 AM
Nkugs90
08-20-2005 03:06 PM
kayvan_pour
12-21-2004 09:19 PM
