TICKING/CLICKING NOISE WHEN ACCELERATING.
Old 05-17-2011, 12:56 PM
djgoldeneye's Avatar
Default TICKING/CLICKING NOISE WHEN ACCELERATING.
Im asking for your help. I recently bought a Audi A4 1999 Quattro and i having an issue with it. Whenever i accelerate the noise, ticking/clicking gets louder. if i am cruising steadily, lets say 60mph in 4th speed its not obvious but if you accelerate then the noise comes back.
Please id like your opinion on this.
Old 05-17-2011, 01:14 PM
mtroxel's Avatar
Does it sound like it's coming from one of the wheels? Bad CV joints click when they get sloppy. Take a look at the boots on your CV joints. Any of them broken and flinging grease all over the suspension?
Old 05-17-2011, 01:16 PM
no its not the cv joints cuz even if the car is stationery and i press the gas pedal and rev high it makes the sound.
Old 05-17-2011, 02:25 PM
mtroxel's Avatar
So it's not when the car's going fast, it's when you're spooling up the motor. Even in neutral? Almost sounds like a fan hitting something.
Old 05-17-2011, 02:27 PM
Tech Guru
4Driver4's Avatar
Almost makes you curious about the type of engine in the car, doesn't it?
Almost.
Old 05-17-2011, 02:28 PM
mtroxel's Avatar
Old 05-17-2011, 04:30 PM
AudiWorld Expert
Reggie's Avatar
Could be the hydraulic lifters have some dirt or sludge in them. Try a can of oil detergent in the oil for several hundred miles and see if it goes away. If yes then change the oil afterwards as the oil will be quite dirty. All oils have some detergent in them but if oil changes were not done regularly sludge can build up - especially in turbo cars where the oil will see more heat.
The other possible cause could be the injectors. Try a can of BG44K in the gas for this issue.
If neither one solves the issue try a local independent Audi shop - look on the local forums for recommendations.
Old 05-17-2011, 06:16 PM
5v/cyl's Avatar
Exhaust manifold leak.
Old 05-17-2011, 11:57 PM
Harddrive2000's Avatar
cam tensioner gasket?
Old 05-18-2011, 05:05 AM
Tech Guru
4Driver4's Avatar
Unpossible. Even without knowing the engine or transmission in this car, I can tell you that an oil leak won't make a clicking noise.
Quick Reply: TICKING/CLICKING NOISE WHEN ACCELERATING.
