Transmission FINALLY died. NEED answers on 2.8 tranny swap! DEAD
Old 10-13-2003, 02:52 PM
skabaru's Avatar
Default Transmission FINALLY died. NEED answers on 2.8 tranny swap! DEAD
so as you may recall faithful readers, my tranny has been on the way out for a bit... loss of 5th gear, nasty noises, and the occasional loss of speedo...
well, at the audi car club chicago chapter autox at tirerack on saturday, I finally lost it... I came in too hot into the final slalom and lost a bunch of speed, so I blipped and downshifted into 1st (as I have done a million times before) and it went in WAY too easy... uh oh... So I stopped in the stop box, car in 1st, clutch on the floor, and it was making HORRIBLE noises and was catching... ****... so I made it out of the stop box (not without much more scary noises and eventaully, using 2nd and still having issues, I made it back to the parking area... a few phone calls later my mechanic (al @ chicago performance and tuning) is on his way with his trailer...
So he comes over, hops in the car, and drives about 5-8 feet... gets out and says "man, this thing is fvcked!"... exactly the words you want to hear from your mechanic...
So he took it to his shop and has found a few 2.8 Transmissions around... BUT
I need to know 100% that this swap is gonna work. I am thinking of those that I know have done it and I am confident it will work, but I want to be sure there are no surprises ahead of me...
so are who has done it, what year car, what year/code tranny... and what surprises if any were there...
I am 99% sure it will drop in without issue, but I want to be sure...
TIA!
Old 10-13-2003, 03:03 PM
Member
Yippers®'s Avatar
Default It will drop in without issue. 100% no problem . Straight bolt in from the starter to the output
shafts and the transmission mounts.
Old 10-13-2003, 03:04 PM
Greyhound Guy's Avatar
I sort of envy you although I wouldnt be able to afford it right now.
Old 10-13-2003, 03:08 PM
Junior Member
The Burnt Audi's Avatar
so what's the advantage of using a 2.8 tranny
Member
zerogrip's Avatar
Default SScott posted about his 2.8 tranny not too long ago.
<ul><li><a href="https://forums.audiworld.com/a4/msgs/1790614.phtml">click&gt;&gt;</a></li></ul>
Old 10-13-2003, 03:09 PM
Member
Yippers®'s Avatar
Better gearing once you have more power. The same reason Audi put it in the 2.8
Old 10-13-2003, 03:11 PM
Rest In Peace
markbradford's Avatar
Couple hundred less RPM to listen to on the highway
Old 10-13-2003, 03:37 PM
Angry Alex's Avatar
it's plug and play, no problem.
Old 10-13-2003, 09:16 PM
Elder Member
lanemeyer's Avatar
Default Better for driving...not drag racing.
But you folks know audi's are not drag racing machines right?
Old 10-13-2003, 09:35 PM
Member
Yippers®'s Avatar
Default Actually it is better for drag racing too. The top of third on the 1.8t is ~92mph. The top of third
on the 2.8 tranny is ~102mph. If you have sufficient power to trap above 92 with in the 1.8t tranny you'll have to shift to 4th before the line. With the 2.8 tranny you can stay in 3rd.
Quick Reply: Transmission FINALLY died. NEED answers on 2.8 tranny swap! DEAD
