Transmission question
I recently had a transmission replacement. It worked for a few hours then stopped shifting in general. The gears won't engage out of park. Ran the computer through it and received a incorrect gear ratio code. Is that possible? If so anyone know what could be wrong now.
Take it back to the shop that did the work!
Low fluid would be my guess, but these transmissions are complicated - the incorrect gear ratio fault is a common one (it refers more to not getting the gear the TCU called for more than the ratios actually being incorrect)
SCarGo02
14
08-21-2005 06:46 AM
[not Steve] Trac
03-07-2002 08:22 AM
