Trouble Code Help
Old 03-23-2004, 02:15 PM
New Member
Pest's Avatar
Default Trouble Code Help
I've gotten a few CEL's in the past 3 weeks and don't know what to do about the codes I've found. Can anyone help?
3 Faults Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
I'm thinking maybe vacuum leak but don't know.
Old 03-23-2004, 02:16 PM
[tri]liament's Avatar
Default i got DTC 17544 when my vac line was torn (the one from front of intake manifold to bpv)
haven't had any experience with the others.
Old 03-23-2004, 02:18 PM
New Member
Pest's Avatar
Default Re: i got DTC 17544 when my vac line was torn (the one from front of intake manifold to bpv)
That particular code (17544) has come up 3 times, if it's not visibly torn, what's a good way to check it?
Old 03-23-2004, 02:20 PM
New Member
Pest's Avatar
if I wanted to log some data, what measuring blocks should I be logging?
FijiTT
01-04-2009 07:29 PM
PaulW
10
11-19-2008 06:42 AM
austinado16
VAG-COM Discussion
03-09-2007 10:36 PM
Audi902
04-11-2006 06:55 PM
JasonS4+Festicle
07-07-2002 06:46 PM
Quick Reply: Trouble Code Help
