Turn key to start position, no dash lights new battery
Old 01-31-2015, 10:53 AM
rpmccas's Avatar
Default Turn key to start position, no dash lights new battery
I'm having issues trying to get my 2000 A4 2.8 to start.
Every now and then, the car will turn over but not start. The battery was getting weak so I replaced the battery. It cured the problem for 3 days and then I started having issues again.
When I turn the key to the start position, sometimes I get no dash lights. (The ECU testing itself) I'll try to start. It turns over but does not start. I'll put the key back to the start position and then all of the indicator lights come on like their supposed too. I'll turn the key off and then back to the start position and then the service light will come on. I'll pull the ECU fuses and put them back in. And then turn the key back to the start position. When it's cold all of the indicator lights will come on and the car will start. It runs perfectly. I will then turn the car off and try to restart and the problem starts all over again. But then I cannot get it to start again when the car is warm. I'll go back the next morning and sometimes it will start, sometimes it won't. I start the procedure all over again.
Any ideas on where to start? When I turn the key on and the ecu test starts the car starts fine. It's when no lights come the dash and the ecu test procedure does not start is when it doesn't start. New battery and turns over fine.
Old 02-02-2015, 06:12 AM
x19
x19's Avatar
Hi, sound like ignition switch makes your problem that I can think of it. Good luck. x19
Old 05-17-2018, 12:59 AM
AurimasL's Avatar
I have the same problem. Every symptom described plus when i manage to start it and drive it for a while it stalls. Everything started when it stalled when i was idling near traffic light. Audi A4 2003 1.9tdi 85kw
mtnxtreme
Q7 MK 1 Discussion
07-13-2015 05:25 PM
Chris470
11
12-28-2012 03:03 AM
s4boosted
01-26-2009 09:00 AM
übertek
Mid Atlantic Discussion
14
06-21-2006 04:44 PM
Quick Reply: Turn key to start position, no dash lights new battery
