VAG codes from my car, what's your take on them?
VAG-COM Version: Release 409.0-US
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 4B0 906 018 P
Component: 1.8L R4/5VT G 0006
Coding: 07201
Shop #: WSC 40831
1 Fault Found:
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
No fault code found.
Address 08: Auto HVAC
Controller: 8D0 820 043 Q
Component: A4 KLIMAAUTOMAT D56
Coding: 00140
Shop #: WSC 06335
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8D0 920 980 CX
Component: B5-KOMBIINSTR. VDO D13
Coding: 02244
Shop #: WSC 08057
Address 35: Centr. Locks
Controller: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16236
Shop #: WSC 06335
6 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00991 - Interior Lights
28-00 - Short to B+
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
Address 56: Radio
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00201
Shop #: WSC 00000
End --------------------------------------------------------------------------------------------------
I have a certified pre-owned warranty so I'm pretty sure this is all covered. Would you just show up to the dealership with this printed out? Also could any of the faults be a result of re-programing the remote to open and close the windows?
Thanks!
Address 01: Engine
Coding: 07201
Shop #: WSC 40831
1 Fault Found:
Coding: 0273004284
Shop #: BB 24334
Coding: 00140
Shop #: WSC 06335
Coding: 02244
Shop #: WSC 08057
Coding: 16236
Shop #: WSC 06335
6 Faults Found:
35-00 - -
35-00 - -
35-00 - -
28-00 - Short to B+
00955 - Key 1
00956 - Key 2
Coding: 00101
Shop #: WSC 06335
Address 56: Radio
Coding: 00201
Shop #: WSC 00000
Thanks!
I've been getting the cent. lock run time code too
My locks work fine AFAIK. Anyone know any common causes for this or fixes?
I was told that this occurs due to hitting the button
too many times or too long with the remote. And yes it can also be caused by programming the remote. But this is only what I was told when I had the exact some problem.
I asked Jose @ Euro-Tech about the cent. locking issues
My car was saying the same stuff about pump run time, and key adaptation limits etc... He said that group 35 just tends to have a lot of codes in it, and not to worry, because it's pretty normal.
After I reset mine, they haven't come back.
BSK
Mid Atlantic Discussion
10-31-2006 04:15 PM
BSK
01-05-2005 01:43 PM
GreekDeno
22
02-15-2004 05:35 AM
