What the #!&? How do you remove the plastic lug nut covers? - AudiWorld Forums
Old 04-25-2001, 05:22 AM   #1
SGP
Default What the #!&? How do you remove the plastic lug nut covers?
Is there a special tool (that may be missing from my tool pouch)? Thanks.
SGP is offline   Reply With Quote
Old 04-25-2001, 05:36 AM   #2
Longwolf (Christian)'s Avatar
Yea, should be a tool in the kit that looks somewhat like wide tweezers.
Longwolf (Christian) is offline   Reply With Quote
Old 04-25-2001, 05:36 AM   #3
There is a tool but you dont really need it. Just use whatever and be careful.
Greyhound Guy is offline   Reply With Quote
Old 04-25-2001, 05:36 AM   #4
Chief Cook and Bottle Washer
Kris Hansen's Avatar
Default The tool is a plastic U shaped deal, use it to hook onto the caps and pull.
you can pry them off (carefully) with a screw driver if need be.
Kris Hansen is offline   Reply With Quote
Old 04-25-2001, 05:36 AM   #5
Default Your tool kit should have included this tool.....
<img src="http://pictureposter.audiworld.com/116/lugbolt-cover_removal_tool.jpg">
This is the correct tool to use to remove the plastic lug-bolt covers. Snaps onto the covers and pulls them right off with no contact to wheel itself. Your dealer will probably give you one if you tell them yours was missing from your A4.
Andy Hedin is offline   Reply With Quote
Old 04-25-2001, 05:42 AM   #6
Elder Member
Regular screwdriver works but be careful!
Matt H. is offline   Reply With Quote
Old 04-25-2001, 05:54 AM   #7
SGP
Default You da man!
I bought the car used; the tool kit has a u-shaped metal tool that my wrench imediately identified as the tool for prying off a moon-style chrome hubcap from a 1960's vintage porsche! And it doesn't work for the A4!
Old 04-25-2001, 05:59 AM   #8
Default That U-shaped metal tool (which I have as well) was used to pull the center caps off of certain....
....wheels. I believe it fits the 15" wheels that have one big cap in the center which hides all the lugbolts. Using that tool to remove the 5 plastic lugbolt caps will cause scratches on your wheels.
Old 04-25-2001, 09:17 AM   #9
Junior Member
I use needle nose pliers. I got the plastic tool mentioned below from the dealer-doesn't cost much
audiohs is offline   Reply With Quote
Old 04-25-2001, 12:09 PM   #10
Member
I bent a big paper clip into a useable U shape to remove them w/out scratches
Stang Guy is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Audi roadside is the biggest joke ever 335i A6 (C7 Platform) Discussion 8 02-05-2017 04:13 PM
DIY Remote start Q5 IntheQ5 Q5/SQ5 MKI (8R) Discussion 27 06-09-2016 01:37 PM
The Daily Build..My S6, the story and the questions vwleadfoot Audi Original "S" Cars 4 12-24-2015 07:07 AM
How to remove steering line retainer? Zumkopf A8 / S8 (D2 Platform) Discussion 1 09-10-2015 06:23 AM
95 Cabriolet Air Conditioning Clutch Removal. stormchaser1967 Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 1 09-02-2015 01:47 PM
Tags
1996, 1997, a4, a6, audi, cover, covers, lug, lugnut, nut, nuts, plastic, remove, removing, vw
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
