What are the symptoms of a bent wheel?...
Old 07-25-2002, 04:33 AM
The Red October's Avatar
Default What are the symptoms of a bent wheel?...
I think I might have a small bend in one of my wheels, but I have visually inspected them and can't see anything... When driving 25 to 45 I get a thunk...thunk...thunk... that seems to increase with speed. Its barely noticeable, I think I feel it in the steering wheel. Any tips on diagnosing this and finding the bad wheel? Or could it be the tires? I have pirelli pzero rosso's with about 10K on and 2 track events on them, they are close to the wear bars. When I put the snows on I don't hear/feel the noise.
Old 07-25-2002, 04:37 AM
Bruno_S4's Avatar
Vibration in the steering wheel (at higher speeds) is the first give away.
Old 07-25-2002, 07:19 AM
Senior Member
omidius's Avatar
Default Generally:
If the noise and vibration is coming from the tires itself, at higher speeds the vibration goes through an oscillating wave of increasing and decreasing power. If it is constant I would think it genenrally means the rim itself. Lucky for you, identifying a rim problem is as easy as two things, grabbing a friend or taking the thing to a rim/tire shop.
Tell a friend to drive aside the car looking at each tire individually travelling at 60 mph or whenever the vibration is most apparrent. Choose a smooth road, clear of traffic. The messed up rim/tire should be very easy to spot amogst the others.
The other thing u can sdo is just take it to a shop to get it balanced. Their machine ill tell them if the balance is off or untrue. A visual inspection of the tire /rim will check for bubbles, dings, dents, or cracks.
Old 07-25-2002, 08:50 AM
New Member
A18T's Avatar
Default Omid...which part of OK are you from?
I'm from OK too, I think I saw your car last nite on May & 36th.
Old 07-25-2002, 10:10 AM
Senior Member
omidius's Avatar
Default Hmm, I wish. i'm doing a project up in Stillwater for the next couple of weeks...
I'd be surprized to see ANY kind of Audi modded or not! I take it you're in OKC?
B56
13
03-12-2007 12:05 PM
eisman.s4
10
07-11-2006 05:30 PM
lucifa v.2.0
10-14-2004 10:50 AM
Rick 601
Audi 100 / A6 (C4 Platform)
9
02-27-2004 07:18 AM
TCP
11-14-2001 06:46 PM
Quick Reply: What are the symptoms of a bent wheel?...
