Why does my compressor decide to randomly turn itself on?
Old 03-16-1999, 12:03 PM
ChrisWB
Guest
Posts: n/a
Default Why does my compressor decide to randomly turn itself on?
Throughout this whole winter in CT, I have had no reason to turn the compresor on. If you only need heat, why bother to turn it on? You can totally hear and feel the drain on the whole system.<p>Once in a while, like this morning, after I turned my car on I notice the compressor is on also. I know I didn't have it on before.<p>What da diley yo? (What's the deal?)<p>ChrisWB<br>99 1.8tqm<br>
Old 03-16-1999, 12:29 PM
Andy Hedin
Guest
Posts: n/a
Default Actually, it's not random at all...
Totally normal operation for the climate control system in the A4. At some point in time you did hit the "Auto" button, which under normal operating conditions (temps above 35 degrees or so [check archives for the exact temperature cutoff]) would turn on the A/C compressor. Chances are, the outside temps in your area have been below that temperature for a while now and the first day above 35 (today), the compressor "magically" comes on.<p>Ways to avoid this:<br>1) Don't use the "Auto" button. Adjust temp, fan speed, air output manually. <br>2) If compressor does come on when you don't want it on, just hit the "*" [snowflake] button to turn off the compressor.<p>Andy Hedin<br>'97 A4 1.8Tqms, Wett 1.0 Bar Chip, ABT Filter, Euro Headlights...
Old 03-16-1999, 12:30 PM
Drew S.
Guest
Posts: n/a
Default Perhaps it came on with defrost to remove humidity?
If you are trying to defog the inside of your windows, having the AC turned on helps immensely. What you need to realize is that just because the compressor is on, doesn't mean that it has to blow cold air. What you can do is use the AC to dehumidify the air and defog the windshield quickly.<br>
Drew S.
Guest
Posts: n/a
Old 03-16-1999, 12:33 PM
tp
Guest
Posts: n/a
Default Re: Actually, it's not random at all...
if someone already said this, sorry, but in addition the compressor will also shut off under full power in order to focus energy on accelleration, then turn on once gas pedal is let up. great idea, but not something Audi thought of first.
Old 03-16-1999, 03:04 PM
Larry Victor
Guest
Posts: n/a
Default Re: Why does my compressor decide to randomly turn itself on? Actually, the problem is sort of the opposite.....
Unfortunately, it appears as though the compressor CAN'T be turned on when the temp is below that mysterious number. I would love to be able to activate it when add'l dehumidification would help defog the windshield. Is this correct? I'd welcome a solution.
Old 03-16-1999, 07:19 PM
HVAC envy
Guest
Posts: n/a
This is a &quot;feature&quot; to prevent damage to the compressor. Almost as annoying as having to have the A/C on to recirc...
Old 03-17-1999, 06:25 AM
ChrisWB
Guest
Posts: n/a
Default I think you may be incorrect.
This morning in CT it was way warmer than yesterday (like 45-50 degrees outside). Compressor did not come on automatically.<p>It just seems ridiculous that it would turn on even in cold or even mild temps. The only time I see a need for the compressor (except to remove humidity of course), is when you want air cooler than the outside temp blowing in. In that case, the compressor should automatically come on in "auto mode" when the outside temp is above the setting on the climate control.<br>
Old 03-17-1999, 07:06 AM
JonC
Guest
Posts: n/a
Default actually, you DO want to run your compressor at times during the winter...
the refrigerant contains a lubricant for seals. It is good practice to run the AC for about 10 mins. every week or two in the winter to circulate the lubricant and keep seals from drying out.
Old 03-17-1999, 07:16 AM
Cathleen
Guest
Posts: n/a
Default Absolutely! My Honda compressor died because of this......
You had to manually turn on the A/C on my Honda Civic sedan. No one ever told me that I should turn it on periodically during the winter when it was above freezing. One spring my A/C compressor died and had to be replaced. The Honda dealer tells me that I should have turned it on at least once a week in the winter because if you don't keep it running now and then it will break down. The car was only 2 years old at that time.<br>So IMO Audi is smart to make the A4 compressor come on automatically now and then to save this potential problem from occuring.<br>-C.
Quick Reply: Why does my compressor decide to randomly turn itself on?
