Need help with rubbing wheel liner
Old 03-31-2003, 08:33 PM
ThirdEye's Avatar
Default Need help with rubbing wheel liner
I just got new wheels with 235 tires and on hard turns they rub the wheel liner. I was wondering what do ppl generally do, do they just remove it? or cut it? or should I just put a 5mm spacer on each side. Thanks
Old 03-31-2003, 08:54 PM
AudiWorld Expert
paul_858's Avatar
Default spacer won't help if you're rubbing the wheel liner, only make it worse actually.
you can attempt to roll the fenders/cut liner roll to reduce the chance or get stiffer shocks/springs or wheel/tire combo
Old 03-31-2003, 09:32 PM
ThirdEye's Avatar
I'm pretty sure it's not going into the fender just the liner, would heat morphing it work?
Pekboy
07-24-2002 12:57 PM
zon
Wheels & Tires Discussion
09-01-2001 05:53 AM
A4agarwal
06-29-2001 02:35 PM
A4agarwal
05-21-2001 03:30 PM
Quick Reply: Need help with rubbing wheel liner
