the car doesn`t register that the left back door is closed
when i close the left back door the interior lights, lights on the door, light under the seat stays on and the monitor in the dash is showing that the left back door is open.
any ideas on what the problem can be?
Audi a4 1,8T 2002 sedan
Hi.
its probably the switch inside the door lock that is faulty. The comfort control module relies on this switch to tell it that the door is shut. You will need to replace the complete lock.
I had the same exact problem. I bet its the ground wire or another wire is cracked in the rubber boot. You can open the door and remove the rubber boot to get to the connector.
Check the wires to see if any are cracked
Thanks !
Thanks for answers
A link to replacing the harness. About mid way down, there is a good picture of the poster pointing to the harness in the door jamb.
https://www.audiworld.com/forums/a4-...-pics-2379267/
BoostFrenzy
05-01-2013 05:22 AM
a4rosie
12-02-2005 09:27 AM
clancy
04-19-2004 05:10 PM
