3.0 camshaft sprocket removal
Old 03-16-2015, 08:48 AM
mitchell01TT's Avatar
Default 3.0 camshaft sprocket removal
I have a massive oil leak at the front of my AVK engine. I am pretty sure it is 1 or all 4 of the camshaft seals. I have done the timing belt 2 times now once because the water pump from Blauparts only lasted 15K miles. Never buying from them again. I have the intake camshaft sprocket bolt completely removed and when I pull on the sprocket it moves about 5 mm and then stops. Is there a key or something I'm missing or do I have to use a puller?
I have searched and searched and have found nothing on how to remove them for the 3.0 AVK engine.
Thank you!!
Old 03-24-2015, 10:36 AM
Just an update...The massive leak was coming from the driver side intake camshaft seal, two visible cracks at the inner sealing surface of the seal. I had to use a small gear puller to remove both of the intake sprockets, but both exhaust sprockets came off once the bolt was removed.
checkpoint
2.0T FSI Discussion
11-10-2015 11:37 AM
tehzimmy
Audi A3 / S3 / RS 3
04-14-2013 10:24 PM
Enclave
05-14-2008 08:17 PM
Ben's e//S2
9
12-07-2002 02:00 PM
Quick Reply: 3.0 camshaft sprocket removal
