3.0L Burning Oil?
3.0L Burning Oil?
Hello,
I got a 2002 Audi A4 3.0L that is burning about 1 quart every 1000 miles.
The car has about 165,000 miles.
It doesn't seem to have any blue smoke from the exhaust...think I be able to really see it with it burning that much oil.
I just replaced the spark plugs (thought maybe I see something), no abnormal wear on them or signs of bad rings.
I was unable to do a compression check when I replaced the plugs. However, the engine runs great, or at least the same as when I got it about 20K miles ago.
There are no leaks WHAT SO EVER under the car, or on any signs of a leak on the engine parts.
I check the dipstick every time the LOW OIL LIGHT goes on...it supports the low light.
I really at a lose of what / where the oil is going? Wondering if anyone has had this issue or any ideas.
V/r
Dan
V/r
Dan
My 2 cents:
Yes, that is high, but it's right on the edge of "normal", meaning unless there is another cause (maybe some 3.0 owners have ideas), it would not drive any action. I drove a Ford 2.3 turbo for 6 years with oil consumption about in that range. Has the car always had regular oil changes with synthetic?
I just sold a 185k Passat that I bought from the original owner at 45k. It always had synthetic timely changes, but towards the end was using a half quart every other fill up. It ran fine, I never saw leakage or smoke either.
It sounds as if your oil consumption is steady. I would suggest you do what I did, on the basis of fill ups. Waiting for a low oil light to come on sounds potentially dangerous.
Read consumer reports article on excessive oil use by some engines. It was a few months ago.
Pacific Fisher
Q5/SQ5 MKI (8R) Discussion
9
09-14-2016 09:59 AM
Barraged
13
02-20-2016 04:24 AM
iXius
2.0T FSI Discussion
02-12-2016 08:00 AM
