A4 3.0 P0011 Camshaft Position - Timing Over Advanced
Old 09-26-2016, 06:35 PM
dvfosho6's Avatar
Default A4 3.0 P0011 Camshaft Position - Timing Over Advanced
So I've been driving my car with this code on since I bought it (about 3,000 miles) and I haven't noticed anything really. It's a little jumping when I press the gas, also delayed reaction sometimes. Not sure if that relates.
I've cleared the code and it comes right back. I had the bank 2 sensor code as well and just wiggled the connection some and it went away, tried same with bank 1 with no luck.
Is this serious or not so much?
Old 09-27-2016, 10:30 AM
lyleswk's Avatar
This could be several things from an improper belt replacement before you got the car to as you note a simple sensor. Without any of the maintenance history, you won't know. As far as seriousness, the ECU will adjust to protect the engine, but if your state is like mine, you won't get a new registration without fixing it.
Old 09-27-2016, 11:47 AM
dvfosho6's Avatar
Minnesota has nothing like that, what state do you live in?
Old 09-28-2016, 11:21 AM
lyleswk's Avatar
Larger city in Texas; look to the left...
Unfortunately, to solve your problem, you are just going to have to start diagnosing. Sensors and harnesses are a good start.
Old 10-05-2016, 08:19 AM
W261w261's Avatar
In CT, any CEL is automatic fail. In addition, I think you can have no more than 1 monitor not clear.
Old 10-05-2016, 02:30 PM
the_duke's Avatar
In MT we do what we want. No testing here.
But to help the OP is sounds like either an issue with a timing belt install or an issue with the system that changes the cam timing. It can be diagnosed with VCDS but either issue is not going to be an easy fix.
John Goss III
04-01-2019 05:07 PM
jmdarri
2.7T V6 Discussion
09-16-2012 09:41 AM
cotawiah
10
05-23-2011 03:42 AM
SpencerB
Audi Original "S" Cars
07-14-2007 07:35 AM
BJC::wokka wokka
02-23-2006 08:01 AM
Quick Reply: A4 3.0 P0011 Camshaft Position - Timing Over Advanced
