A4 temp gauge faulty
Old 06-19-2015, 08:15 AM
hlscal's Avatar
Default A4 temp gauge faulty
My 2002 A4 temp gauge or sensor is faulty...it registers normal temp, then needle drops to cold, then back to normal...more often, it wont register any heat for at least 10 min of driving...H
Old 06-19-2015, 08:20 AM
hlscal's Avatar
test
Old 06-21-2015, 09:25 PM
John535is's Avatar
Sounds more like a broken wire than a faulty sensor and so unless you have had the dash out recently, less likely to be a dry joint on the instrument panel and more likely at the motor end. Depending on how long since the sensor (the green one) was replaced, I would be replacing that one and checking the wiring connections and if the wires on the back of the plug are damaged.
fluidparkour75
08-18-2018 02:57 PM
iamdrewseph
10-01-2015 11:33 AM
smiladon
10-01-2015 01:31 AM
Dion Block
Q7 MK 1 Discussion
09-30-2015 08:30 AM
Nathaniel411
Audi allroad
09-26-2015 11:30 AM
Quick Reply: A4 temp gauge faulty
