AC Compressor don't get power
Hello. So I have this problem. My AC stopped bloving and today I got it checked, and servise says, that compressor doesn't get power. So maybe someone of you had to deal with something like that, and know if the wires might be cut off some where or there might be something else? And if its wires fault, where usually they might be broken?
Sorry for my bad english. Thanks.
Does the ECON light turn off? Have you hooked up a scan tool and checked faults, if none, you would want to go through the "measuring blocks" in VAGCOM and find one about compressor cut off, and it will have a number, 0 means nothings wrong its trying to energize the compressor, 1-12 signify a reason its being disabled. From A/C pressure signal too high or low, to no rpm signal, ambient temp too low, engine overheat, ect ect. If you dont have VAGCOM, or a high end scan tool that can read the codes from the climate head, you will have a very difficult time fixing the a/c.
CanadianQtip
S4 (B8 Platform) Discussion
9
03-05-2011 03:44 PM
