Alarm lost beep
Alarm lost beep
My alarm doesn't beep. Lights flash as if it's arming but no beep ever. Not when hitting panic or opening doors. Checked fuses but didn't find any correlation. Any ideas? Hope my silent flashing lights scares people away.
alarm beep
does the lights flash when you open the doors as if the alarm get activated?
if so, check the fault for alarm horn, it has it's own back-up battery and usually corrodes the connector, is located in the trunk in sedans and on the passenger side under the cober for the top on convertibles
Thanks for the suggestion. I will def look into this. I haven't pulled any codes b/c I don't have the reader. Lights seem to function completely normal as if the alarm is fully functioning on mute. I'll take a look at the connector and update in hopes of curing other people similar issue.
Good suggestions. If you get nowhere with those, I have a similar problem. But first a question: when you hit the key fob and the lights flash, does the driver's door (or for that matter any door) not lock? If so, I would bet the harness in the door is broken not allowing the lock to be commanded lock and therefore the alarm not setting. That is my issue. See the recent link below for long and boring dissertations on the subject.
https://www.audiworld.com/forums/sho....php?t=2797595
I have the same issue - no beep, but the alarm is fully functional. Is the alarm module in the rear trunk area on the Avant? Any pictures you might be able to share so I know what I'm looking for?
Thanks!
Thanks!
piblondin, did you get your issue fixed? If not, the link below looks like a good DIY.
http://www.audizine.com/forum/showth...ht=alarm+avant
nwa4avant, based on the location in the sedan, I would bet it is in the same location. Look at the DIY above.
jonathanfilippi
09-11-2015 07:52 PM
