Audi 3.0L V6 timing belt service DIY (BWW)
#61
Timing Belt A4 3.0 Replacement Photos
Hi,
Thanks for the post. I am wondering if you can send me the photos that go with it. They are no longer on the site. If you can either e-mail them or put them back up, it would be greatly appreciated! Thanks! Joe
#62
2004 Audi a6 3.0 v6 cam timing
I recently purchased a audi a6. 2004 3.0 v6 . And tore it all apart to replace the head gaskets..rushing more then I should have I never marked anything . Well now i have my parts.. and I'm going to put everything back together and ran into the issue of cam timing.. I've read a lot on it and done my research and I know I need a cam tool! But I never marked anything to help me realign ..I'm wondering if anyone who has previously done this job and marked it.. if they took photos possibly or know where my marks are or should be.. I've purchased an e version of the repair manual and it didn't tell me anything I didn't already know..any help is much appreciated !!!!
#68
Great writeup, and definitely helped me in replacing the water pump and timing belt on 2004 A6 Avant. I bought the cam tool kit, worked great. If anyone want the kit, I will sell it for 50 bucks. Both cam holders, the crank pin, a good pin to stick into the belt tensioner ( its the one that my new tensioner was shipped with, the cam socket tool, and the wrench for rotating the right side idler into place. I hope to never use it again :-). The job is time consuming, but relatively straightforward. Just takes patience.
#69
I did timing belt job recently everything went good except for my cam tools did not fit the best and therefore did not take the cams loose I thought I had marked everything and got it together good and everything seemed great..runs awesome but now I got check engine light random misfire on driver side head but it doesn't feel like it misses or any other symptoms just the light someone on here said I must have installed it wrong so I plan on. Tearing it back down and redoing the job any advice you'll can give me will be appreciated .
#70
What cam tool did you use?
