Audi A4 1.8T 2003 -Mysterious Coolant leak
I have an Audi A4 1.8T 2003, i got it with the coolant leak problem already. The car only has 130k everything was changed on 110k (turbo, timing belt etc). The car was owned by the girl, and the coolant that they put it was not B12-13, something else. For a while the car would stop loosing coolant, but recently i found time to flush the system and put proper B12 coolant in it, after that it started leaking a lot. Here is some pictures from the bottom of the car, the coolant is leaking showing on the oil sensor.
Today i took the alternator apart to really see where does it leak from and here it is (pictures bellow). I have the second most reliable in the world car Subaru outback so i can take time an work on this one without any rush. Anyway form the pictures what do i need to do here? what parts need to be replaced? What do all the pictures tell you?
Additional info: Car doesn't overheat even if i dont add coolant, runs with no problems, spar-plugs a clean as whistle. If i take the thermostat off what do i need to reseal it? To me looks like it's that thermostat elbow that is leaking, shell i get a new thermostat as well? and there do i get the elbow, and how to seal it? May be i just need to reseal it?
Thank you.
Thank you.
I would be replacing the thermostat, if you get the kit from ECS (P/N 06B121111KKT) or whoever you purchase your parts from they have a kit (either Genuine parts or aftermarket) that has the thermostat in the housing, a new O ring, the J plug and bolts etc. It's mounted in such a fiddly spot if you are going to pull it off to 'check it' I would just replace it with new, same amount of effort, judging from the photo's you need a new O ring and J plug so replacing the thermostat after 12 years is worthwhile, especially if the engine has had some coolant that you don't know the origin of, some 'gunk' can settle around the thermostat and create problems.
I had to do the water pump on mine recently, surprising how much water the system can loose and not overheat, probably points to a very efficient cooling system design on these engines.
here is the video, how this Eastern European guy does it for less then 30 min
sissupr
06-23-2003 07:38 AM
