Can't Get Rid of Misfire - AudiWorld Forums
Old 04-08-2014, 03:57 PM   #1
Default Can't Get Rid of Misfire
To start, my audi had several misfire issues and codes. Since then most of the codes have been resolved except:
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 008 - Implausible Signal - Intermittent
16686 - Cylinder 2: Misfire Detected
P0302 - 008 - Implausible Signal - Intermittent
I have replaced all 4 coil harnesses. New Spark Plugs. New check valve. New suction jet pump.
After seeing the two cylinders misfire I assumed the problem was bad coils. I rearranged the coils, cleared the codes and the same three codes appeared again. Any ideas??
Riley Turner is offline   Reply With Quote
Old 04-09-2014, 05:18 AM   #2
1.8 or 3.0?
After all that, the only other thing to look for is vacuum leaks. I would also check to make sure your air filter is clean...
lyleswk is offline   Reply With Quote
Old 04-13-2014, 01:49 AM   #3
Bad rings or valve guides causing plugs to oil foul? How many miles?
10speed is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Camshaft replacement sensor code problems brandonb93 A4 (B7 Platform) Discussion 10 12-01-2015 07:51 PM
Hi Guys 96 B5 owner smiladon A4 (B5 Platform) Discussion 6 10-01-2015 02:31 AM
Where is the ICM/POS on 2008 A8L 4.2? beachcomber A8 / S8 (D3 Platform) Discussion 8 09-30-2015 10:02 PM
I'm now an Audi Owner, first time ever. Jasp615 Q7 Discussion 4 09-27-2015 08:19 AM
Audi TT quattro Cylinder 4 misfire HELP!! amdreamer1 TT (Mk1) Discussion 0 09-26-2015 07:56 PM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
