the car doesn`t register that the left back door is closed
Old 10-25-2014, 05:47 AM
beihokk's Avatar
Default the car doesn`t register that the left back door is closed
when i close the left back door the interior lights, lights on the door, light under the seat stays on and the monitor in the dash is showing that the left back door is open.
any ideas on what the problem can be?
Audi a4 1,8T 2002 sedan
Old 10-28-2014, 01:56 AM
gsjohal's Avatar
Hi.
its probably the switch inside the door lock that is faulty. The comfort control module relies on this switch to tell it that the door is shut. You will need to replace the complete lock.
Old 10-31-2014, 08:49 PM
pearlwhitesix's Avatar
I had the same exact problem. I bet its the ground wire or another wire is cracked in the rubber boot. You can open the door and remove the rubber boot to get to the connector.
Check the wires to see if any are cracked
Old 11-02-2014, 10:11 AM
beihokk's Avatar
Default Thanks !
not quite sure what you mean, can you maby link a photo?
Thanks for answers
Old 11-02-2014, 06:35 PM
the rubber boot that covers the harness going from the body to the door. Open the door and look at the space between the door and body near the door hinge.
Old 11-05-2014, 08:53 AM
lyleswk's Avatar
A link to replacing the harness. About mid way down, there is a good picture of the poster pointing to the harness in the door jamb.
https://www.audiworld.com/forums/a4-...-pics-2379267/
BoostFrenzy
05-01-2013 05:22 AM
jmuecke
A4 (B7 Platform) Discussion
04-28-2010 01:11 PM
A6-'99-1.8T
04-09-2007 10:18 AM
a4rosie
12-02-2005 09:27 AM
clancy
04-19-2004 05:10 PM
Quick Reply: the car doesn`t register that the left back door is closed
