Car Shaking/Check Engine Light/High RPM on idle
Old 04-30-2012, 08:29 AM
LoPoVe's Avatar
Default Car Shaking/Check Engine Light/High RPM on idle
So this happened in a short time period. Over this past weekend I was driving my car and at stop lights I noticed the car was shaking, it went away when I accelerated. Then when I woke up this morning my check engine light came on and the shaking of the engine was worse. The engine seems to be louder than usual. I drove immediately to auto zone and got the following codes:
P0300 - random misfire
P0301 - Cylinder 1 misfire
P0302 - Cylinder 2 misfire
P0303 - Cylinder 3 misfire
P0304 - Cylinder 4 misfire
P0507 - Idle Air Control System RPM higher than expected
P0171 - System too lean (Bank 1)
When the car is in motion everything seems fine except for the check engine light being on.
Any ideas?
Old 04-30-2012, 08:31 AM
LoPoVe's Avatar
I changed the ignition coils and spark plugs when the recall happened about 2 or 3 years ago. I also need an oil change and I will be doing that any day now.
Old 04-30-2012, 08:32 AM
LoPoVe's Avatar
Also I changed the timing belt when I had 90,000 miles, I now have 156,000 miles.
Old 04-30-2012, 09:35 AM
lyleswk's Avatar
That sounds more like a vaccuum or intake leak.
Old 05-01-2012, 03:46 PM
joelj's Avatar
Default Hmm
Sounds like a PCV issue. I had the exact same problems, misfire at idle along with all those misfire codes. Have a reach under and check all the pcv lines and hoses. Turns out the one connecting to the oil filter was disintegrating as when we pulled it off it literally crumbled.
Old 05-01-2012, 03:57 PM
ggcrash's Avatar
Sounds like a some sort of VAC leak, I agree with lyleswk.
Check your suction jet pump...(do a search for the item, because I don't have any photos)
Old 05-07-2012, 05:59 PM
LoPoVe's Avatar
Gentlemen,
Thank you for the replies. It was a vacuum leak. I had a mechanic replace the black plastic valve, cost me $180. I think I got off easy. Car runs like brand new. I hope my audi lasts forever.
ramzisleiman
08-21-2017 12:57 AM
Ande1160
05-13-2014 06:15 AM
shahriq
01-13-2006 02:37 PM
HRockwell
10-10-2003 11:25 AM
Just Gizmo
10-25-2001 06:46 AM
Quick Reply: Car Shaking/Check Engine Light/High RPM on idle
