CEL - P0456 - EVAP small leak troubleshooting - AudiWorld Forums
Old 04-03-2007, 08:18 AM   #1
New Member
Default CEL - P0456 - EVAP small leak troubleshooting
Last night my CEL came on, so when I got home, I plugged in my VAG-COM and pulled this code:
<b>16840 - EVAP System: Very Small Leak Detected
P0456 - 002 - Lower Limit Exceeded - MIL On</b>
I had this code last fall (intermittent, no CEL) and reseating the hoses on the N80 purge valve behind the airbox solved the problem. No such luck this time.
I leak tested using block 71 in Basic Settings. I removed and replaced the gas cap. I jiggled the hoses on the purge valve again. So far the leak tests have all come up Small Leak, <b>except when I disconnected the left-hand hose from the purge valve and plugged it.</b>
Here's the purge valve:
<img src="http://www.patzcatz.com/audi/evapleak1.jpg">
Here's the hose I disconnected and plugged, which resulted in NO leak detected:
<img src="http://www.patzcatz.com/audi/evapleak2.jpg">
What I'm wondering is, if disconnecting the purge valve and plugging the line stopped the leak, does that mean my purge valve is bad?
I'm going to buy some reusable hose clamps today, and do some more troubleshooting. So far that one connection was the only one I could remove easily last night without destroying the one-use clamp.
I found EricVonHa's writeup here and read through it, and the fact that my leak test passed with the line from the canister to the N80 plugged, that my N80 is allowing a small amount of flow when closed. Sound like a plausible theory?
BTW, can I buy the N80 purge valve at a Pep Boys/Autozone, or would I have to hit up an Audi dealership?
TIA,
Kevin
kpatz is offline   Reply With Quote
Old 04-03-2007, 08:31 AM   #2
Member
Default Could be a bad gas cap, do a search on
the code P0456 - 002
A4Huey is offline   Reply With Quote
Old 04-03-2007, 09:04 AM   #3
Senior Member
Default I had a similar issue last spring
according to the dealer it was a malfunction in the solenoid to the purge valve cap. The same problem has occured twice so I wonder how prone they are to failure (or maybe I'm just unlucky).
clean. is offline   Reply With Quote
Old 04-03-2007, 09:15 AM   #4
AudiWorld Uber User
Default That's the issue that I had as well (although no CEL). The dealer 'updated my ecu' whatever that...
means and the problem went away. I was all stock back then.
Tgr_Clw is offline   Reply With Quote
Old 04-03-2007, 10:37 AM   #5
New Member
Default Re: Could be a bad gas cap, do a search on
I doubt it's the gas cap, since the leak test passed when I plugged the hose going into the purge valve.
From what I've read, when the ECU tests for leaks, it pressurizes the system, then closes the purge valve for 15 seconds or so and a reed switch closes if the pressure leaks out.
When I plugged the line going to the purge valve, the test showed no leak. This makes me think that the purge valve is leaking, or letting pressure through when it's closed. If it was the gas cap, it would still leak even with the hose plugged or clamped.
I'll pull the valve and fiddle with it, and put decent hose clamps on, and try plugging the other side when doing the leak test, and see what happens. I have a new valve on order, just in case.
Old 04-03-2007, 02:04 PM   #6
Senior Member
Default Check the underside of that grey and black check valve. Mine was cracked on
the underside a few months back, but the top side looked fine. I changed it before a failure, but it was obvious it was only a matter of time.
Bronze is offline   Reply With Quote
Old 04-03-2007, 03:10 PM   #7
New Member
Default Replaced purge valve, problem solved!
I dropped by the local VW dealer on the way home from work (much closer than the Audi dealer) and picked up a new purge valve. I put it in, cleared codes, and ran evap flow and leak tests, and everything passes now. Problem solved, and no more annoying yellow CEL on the dash.
Old 04-03-2007, 03:11 PM   #8
AudiWorld Expert
Merkin is offline   Reply With Quote
Old 04-03-2007, 03:11 PM   #9
New Member
Default Re: Check the underside of that grey and black check valve. Mine was cracked on
My check valves look fine, and my clamp test showed it was the purge valve anyway. I may pick up a few spares to keep in my trunk, along with the spare coilpacks I hope I'll never need...
Old 04-03-2007, 03:12 PM   #10
New Member
$93.05 at local VW dealer.
Thread Thread Starter Forum Replies Last Post
Why I hate NJ's numbnuts rules... carl viking A8 / S8 (D3 Platform) Discussion 34 08-22-2016 08:44 PM
Slight coolant leak - need some advice carl viking A8 / S8 (D3 Platform) Discussion 14 05-26-2016 10:53 PM
Help set me straight; Cam plugs, tensioners, etc.. Tahoesilvers4 Audi allroad 9 09-22-2015 07:11 AM
2004 Audi A6 2.7T tiptronic - CCM flooded - rewired vtraudt A6 / S6 (C5 Platform) Discussion 0 09-17-2015 10:51 AM
Please help! Audi TT MK2 2008 - Possible Vacuum Pump Leak - MIL ON FedericoDC 2.0T FSI Discussion 0 09-05-2015 12:45 PM
Tags
2005, a4, audi, bad, code, evap, leak, p0456, purge, small, solved, system, valve, volkswagen, vw
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
